I have recently installed a CT100 thermostat and I have the Keep Me Cozy smart app installed. The CT100 thermostat allows for the temperature to set at half-degree increments i.e. 25.5, but the smart app does not. Could anyone tell me how to modify the Keep Me Cozy code so I can set half degrees?
try changing the input type from number
to decimal
section("Heat setting...") {
input "heatingSetpoint", "decimal", title: "Degrees?"
section("Air conditioning setting..."){
input "coolingSetpoint", "decimal", title: "Degrees?"
This will allow you to at least input a decimal number.
Whether thermostat.setHeatingSetpoint(heatingSetpoint)
and thermostat.setCoolingSetpoint(coolingSetpoint)
will handle the decimal properly is up for testing on your side.
It worked! Thank you
Awesome! glad to hear it
