Model TS0216 Siren integration
Is there anywhere I can find a driver for the siren Model TS0216 on SmartThings? I have searched but am unable to find. It only lists as ZigbeeThing when I connect to my hub.
Try the “ZigBee Smoke/CO Detector Mc” driver. You can find it at the following link.
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
Hi Thank you for the reply, your solution is not working, neither are the Siren drivers on that channel.
From that channel install the ZigBee Thing Mc driver, and connect your devices to it. Then go to history of the device and make a screenshot of it and post it hear.
This is what my ST page is showing me after changing driver to Mc
@Mariano_Colmenarejo
Can you add this device to Zigbee siren MC driver.
@Darcia14
Added to this driver version
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
 Name         Zigbee Siren Mc
 Version      2024-11-14T15:52:58.695591879
- id : TS0216/_TYZB01_a5tf0bpl
    deviceLabel : Zigbee Siren
    manufacturer : _TYZB01_a5tf0bpl
    model : TS0216
    deviceProfileName : switch-alarm
Thank you so much it works!
