Mode change weirdness
I’m trying to use the good morning mode change to turn on a light. When i use the mode change when it is already in home mode, it turns the light on fine. When I use the mode change to go from night to home, the light blinks. Is there something weird programmed into it? How can I fix it?
What actions is it showing in the “Hello, home” feed?
I actually just figured it out with the help from ST support. I had the big OFF app installed, and it runs whenever there is a mode change. I uninstalled the app and it works perfectly now. I also learned about using the dashboard for the big off function as well.
