MIMOLite Generic Device Handler
Thought I would post this solution for a long term un-occupied vacation home. I have currently used the MIMOLite to monitor for a Freezer Alarm and to interface to a VIVOtek Camera solution. The only standard Device Handler is the MIMO Garage Door Handler which for some reason you can’t use as a template. If you need just a contact sensor, there are less expensive solutions. I have used Everspring SM-103 (battery Powered) to interface to a street power fail relay. Also a Remotec Dry Contact Module (Wired) to connect to my existing X10 alarm with success. The MIMO for the camera required all the MIMO features. I run the camera, SThub, router and a backup sump pump off a group 29 battery. The camera has a pair of dry contacts - one Input (MIMO Relay) and one output (MIMO Contact). The battery has a 30w solar panel to keep it charged. For backup charging, there is a standard battery charger powered from an Aeon switched pigtail (110v). So the reason for the post was that I wanted to see the MIMO relay and contacts treated as distinct entities, and could not find anything. The power needed to be straight forward for monitoring if the solar was not keeping up. I am an old assembler programmer, but the tools and syntax are all foreign to me, so I tried to make my insertions simple (The contact part / the relay part / the powered part). I was not able to figure if you could put a device init routine in so I put the command for joining group 3 into the Refresh button (It is under the Configure button in the garage door opener). I have an app to monitor the battery that is running all the time, and a second app to interface to the camera that is only run in away mode.
Here is the Device Handler if you want to use it. I don’t think the eventHandlers in the middle are used, but didn’t want to remove the code.
 *  Fortrezz MIMOlite
 *  Author: Based on SmartThings code
 *  Also based on MIMOlite GarageDoor code from JitJack
 *  Date: 2016-30-01
 * MAKE SURE TO HIT "REFRESH BUTTON" (mobile app) to have hub join Group 3 (alarm report for power).
// for the UI
metadata {
	definition (name: "MIMOlite Generic", author: "bsa1969@yahoo.com") {
		capability "Polling"
		capability "Refresh"
		capability "Switch"
		capability "Contact Sensor"
		attribute "powered", "string"
		command "on"
		command "off"
		fingerprint deviceId: "0x1000", inClusters: "0x72,0x86,0x71,0x30,0x31,0x35,0x70,0x85,0x25,0x03"
	// simulator metadata
	simulator {
    	// status messages for Relay
        status "on":  "command: 2503, payload: 00"
		status "off": "command: 2503, payload: FF"
		// reply messages
		reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
		reply "200100,delay 100,2502": "command: 2503, payload: 00"
		// status messages for contact
		status "open":  "command: 2001, payload: FF"
		status "closed": "command: 2001, payload: 00"
        //staus message for Power status
        status "powerOn": "command: 7105, payload: 00"
        status "powerOff": "command: 7105, payload: FF"
	// UI tile definitions
	tiles {
        standardTile("contact", "device.contact") {
			state "open", label: "DO Contact Open", icon: "st.contact.contact.open", backgroundColor: "#79b821"
			state "closed", label: "DO Contact Closed", icon: "st.contact.contact.closed", backgroundColor: "#FF0000"
        standardTile("switch", "device.switch", canChangeIcon: true) {
			state "on", label: "DI Switch On", action: "switch.off", icon: "st.switch.switch.on", backgroundColor: "#FF0000"
			state "off", label: "DI Switch Off", action: "switch.on", icon: "st.switch.switch.off", backgroundColor: "#79b821"
        standardTile("refresh", "device.switch", decoration: "flat") {
			state "default", label: "Refresh", action:"refresh.refresh", icon:"st.secondary.refresh"
        standardTile("powered", "device.powered", inactiveLabel: false) {
			state "powerOn", label: "Power >11 vdc", icon: "st.switches.switch.on", backgroundColor: "#79b821"
			state "powerOff", label: "Power <10.5 vdc", icon: "st.switches.switch.off", backgroundColor: "#ffa81e"
        valueTile("alarm", "device.alarm") {
			state "alarm", label:'${currentValue}'
		main (["switch", "contact"])
		details(["switch", "contact", "powered", "refresh", "alarm"])
// This is the main entry point for interupts coming from the device.
	log.debug "MIMO Device Handler - Parse. Description is: ${description}"
    def result = null
	def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1])
    if (cmd.CMD == "7105") {				//Mimo sent a power loss report
        if (cmd.v1AlarmLevel == 255) {
            sendEvent(name: "powered", value: "powerOff", descriptionText: "$device.displayName Lost Power")
       } else {
            sendEvent(name: "powered", value: "powerOn", descriptionText: "$device.displayName Regained Power")
    else if (cmd.CMD == "2001") {			// Contact Sensor Report
    	// Often the MIMO does not send a power restored event, so the following is a catchall.
        // This does not seem to be the case when it is senseing a supply battery low as opposed to a disconnect.
        if (cmd.value == 255) {
            sendEvent (name: "contact", value: "open", descriptionText: "$device.displayName Contact Open")
        } else {
            sendEvent (name: "contact", value: "closed", descriptionText: "$device.displayName Contact Closed")
    else if (cmd.CMD == "2503") {			// Switch Status Report
            sendEvent (name: "switch", value: "on", descriptionText: "$device.displayName Switch On")
        } else {
            sendEvent (name: "switch", value: "off", descriptionText: "$device.displayName Switch Off")
	else if (cmd) {
		result = zwaveEvent(cmd)
        log.debug "Parsed ${cmd} to ${result.inspect()}"
    } else {
    log.debug "Non-parsed event: ${description}"
	return result
// Note: Normal switch, contact, and power status are handled in the Parse handler. The Event handlers are typically not used.
// On, Off, Poll, and Refresh (below) are used.
def sensorValueEvent(Short value) {
	log.debug "sensorValueEvent - Parse returned ${result?.descriptionText}"
    if (value) {
		createEvent(name: "contact", value: "open", descriptionText: "$device.displayName No Camera Event")
	} else {
		createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName Camera Event")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
    log.debug "zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) "
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
	sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
	[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
    log.debug "zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) "
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
	sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
	log.debug "Alarm Event ${result?.descriptionText}"
	sensorValueEvent(cmd.sensorState)
	log.debug "zwaveEvent(physicalgraph.zwave.Command cmd)"
	// Handles all Z-Wave commands we aren't interested in
def on() {
	delayBetween([
		zwave.basicV1.basicSet(value: 0xFF).format(),
		zwave.switchBinaryV1.switchBinaryGet().format()
        // log.debug "line 138"
def off() {
	delayBetween([
		zwave.basicV1.basicSet(value: 0x00).format(),
        // log.debug "line 146"
def poll() {
    log.debug "Polling"
def refresh() {
    log.debug "Refresh - This will also join Group 3 which allows for the Powered messages to come through"
    zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
Thanks for sharing … quick hint though; surround your code in three back-quotes to ensure it is all formatted nicely into one block.
i.e., use the </> formatting tool after highlighting the code.
/* Java or Groovy code here */
Thanks - I was able to use the button in the formatting menu </>
The java idea didn’t work while editing an already screwed up post. Sooo much to learn.
FYI: fortrezz has a device handler for mimolite in Github
Has anyone written a Device Handler for use with the MIMOlite when used in Latching Relay Mode? I would like to monitor a 12vdc output that is constant, and report the status (active or off) to Smarthings so other devices can be triggered. Switching and alarms are not needed for my implementation. Thanks!
The changes I did in the Mimo driver were to insure that the switch function and the contact function operated independent of each other. Since I drive the Mimolite off 12vdc batteries, I worked on the ability to notify SmartThings when the battery was at low (no) voltage, and when it returned to normal.
I use 2 mimoLites to drive a 12vdc camera - the switch on one turns the camera on and off, the switch and contact of the other are wired to the camera event relay and sensor (2 way communications between the camera and SmartThings. The third MimoLite is used to monitor a freezer temperature sensor. I wanted to use a thermal sensor and read the actual temp of the freezer, but I took the easy way out and used a temp monitor that has a contact interface, so now it is just normal or in melt down.
Hi… kinda new guy. I have the Mimolite. I am using a handler from one of these forms “FortrezZ Flow Meter Interface”. Every thing seems to be working exactly as I expect. I can see on the input pins when 12V is applied and when it’s removed in the app and in the logging. Where I run into trouble is despite those values being passed on, I cannot figure out why Webcore cant seem to see anything other then the standard device “definitions?(like status)”. Basically i want to trigger on the presences of the 12V and switch the relay. Any help would be great.
i guess maybe a better way to ask is what defines what Webcore can see/use from the device?
