FortrezZ Mimolite and edge drivers
Hello, I currently have a custom app that notifies when “power is out”
I do not see an attribute for “power out”: when I try and create a routine that checks the mimolite status.
Will the mimolite device be supported with edge drivers?
If it is, is there an attribute for the “power out” feature?
Only if FortrezZ creates one, otherwise it should default to a generic zwave switch. My money is on FortrezZ NOT developing an edge driver.
Thanks for the info, added the word FortrezZ to the title for others if they have similar question.
Interested in this as well. Just curious if any of you had any new info. Thanks!
I am very interested in this as well.
Thanks to @philh30 who passed this along.
Channel invite:
One simple home system. A world of possibilities. | SmartThings
Build a smart home to support all your big moments. With SmartThings, your home becomes a connected space that makes your life simpler, safer, and more entertaining.
Source code:
github.com
ST-Edge-Drivers/FortrezZ/MIMOlite at main · philh30/ST-Edge-Drivers
main/FortrezZ/MIMOlite
Contribute to philh30/ST-Edge-Drivers development by creating an account on GitHub.
@philh30 is there any way to add an option to the driver so that Mimo Switch is recognized as a type lock or door so that the states are open/closed instead of Off/On. I think there are a few people that use the Mimo to control garage doors or maglocks and it would be great to have that nuance fixed. Thanks Manel
I use MIMOLite as a garage door opener with the J5 jumper removed to make it a momentary switch. Do I need to put that jumper back now? I now have to double-tap the app button and it also doesn’t report the correct state of the reed switch sensor I installed. (This is the same condition for both this MIMOlite edge driver and the SmartThings generic garage door opener driver)
Hi, just recently migrated from Vera to Smartthings. The grass is greener here. I like the user interface and how the sensors sync with Amazon Alexa. Need help on configuration of the Fortrezz Mimo2+. Is there an edge driver for it already?
Hi - I am also in search of a Fortrezz Mimo2+ edge driver.
