Meross garage door opener status problem!
UPDATE;
I got an e mail from Meross which i want to share with you
Dear Can Saraç
We encountered the same problem when use smartthings app to control the garage door. Don’t worry, we have noticed the issue and our team will feedback this issue to smartthings, hope the issue will be fixed later. (17.08.21)
Problem
Hi all, i am using meross garage door opener for somtime. I bought esspicially for smartthings, paired easily, works well HOWEVER
Problem is, its showing “closed” condition after immidiatly i push the button to close the door. So its saying closed way before it closed,
Interestingly when i refresh after it say “close”, it return to “open” and status not show close until the door close.
For manuel open , when i open from key or original button of device smarttings show that its checking contact sensor situation (shows correct status i meant…).
So basicly smartthings not checking the “status of contact sensor” it checking if i click the button, when its used on the smartthings app.
Its shows me that there is a handler error however i dont know how to solve that,
To just not it, you can add meross product from smartthings app, i didnt coppy paste or create a handler or somthing like that
Thanks in advance!
I am putting the video of the issue i record about…
Can Saraç
You should contact Meross support as they own and maintain the integration with SmartThings. They generally respond fairly quickly to questions.
https://meross.com/support/Email_Support
Ok i sended hope they can solve!
Was this ever resolved? I think the integration still does not show the correct state unless manually refreshed.
Last time i tried, issue was still remains. I did not contact with meross again, I think this issue will not going to be solved compleatly. Such a shame cause it is a really nice affordable device but since it comes to a such security concern reliability is very important.
Sorry about that! If it will ever get solve or if they send me a message i will share here however my guess is it is unlikely.
I do not experience this issue (but I use iOS) so there is hope for you :slight_smile:
