Hi,
has anyone succeeded in connecting melcloud (mitsubishi) ?
Frederik.
Bernfp
November 28, 2023, 4:33pm
3
I have a vitual integration with the help of Alexa.
As Alexa have a skill integration for Melcloud, I use Alexa multitriger virtual device in ST to send device status change to Alexa and then with routines in Alexa you can control few parameters of Meltcloud (Mitsubishi system).
See below:
For those having Alexa integration reliability problems:
Iâve whipped up a new driver to test a theory that the combination switch+contact sensor could be problematic now for some reason. This driver takes a different approach so we can test if a contact-only device is more reliable as an Alexa trigger. It will take several of you trying this over a period of time to see if it proves to be more reliable. For those willing to give this a shot, instructions below:
Go to my test driver channel and choose to install âAlexa Multi-Trigger v0.1â.
Once available on your hub, do an Add device / Scan for nearby devices and a new device called âAlexa Multi-Triggerâ will be created. Open this new device and youâll see slots for 19 triggers - each with a name you can edit and a switch. Once yoâŚ
