This post serves as the home for information on Hub support for Matter OTA (Over the Air) firmware updates and the current list of Matter devices able to be upgraded via SmartThings during this Controlled Rollout phase.
Starting with the 47.10 hub firmware, Matter-supported hubs will have Matter OTA Provider support enabled, meaning the hub can automatically perform OTA firmware updates on eligible Matter devices to a newer firmware that has been certified by the CSA and published to CSA’s DCL. Unlike Zigbee where the device’s firmware is packaged and released along with Hub firmware, Matter device firmware is downloaded from the Manufacturer’s host server.
SmartThings will be rolling out OTA support in 2 phases:
Controlled Rollout Phase: SmartThings will initially take the extra precaution to vet out and validate Matter device firmware published to the DCL prior to enabling them for customers. News about the duration of the Controlled Rollout Phase as well as the list of verified devices currently eligible for Matter OTA updates via SmartThings will be updated here on this post.
All Devices Eligible: In the near future, SmartThings will remove this temporary measure of vetting device updates first and take a more hands-off approach to allow for Matter OTA updates for any device that has CSA Certified Firmware in the DCL.
To enable updates for matter devices, follow the steps below.
Open the SmartThings app and select your SmartThings hub
Choose More Options (⋮) and tap Settings
Select Device firmware updates and choose Allow
Once enabled, the hub will automatically update the firmware for your Matter devices if a new one becomes available
Devices Currently Eligible for Matter OTA via SmartThings:
My eve motion updated from 3.1 to 3.2 overnight. Only found out because the lux reading started working Is there a way to tell whether SmartThings was the Matter controller that applied the update?
Good afternoon, when will the update for the Qingping Thread temperature and humidity sensor be released? According to the manufacturer, the Thread sensor will be updated to Matter in the future. I’ve tested it on android and it still doesn’t work with smartthing hub via thread matter. In this case, how am I going to get the matter thread code for this sensor, which only has the Homekit code?
I am seeing the same thing with my SmartThings Station as well, and all of my Eve Motion devices are still stuck on version 3.1. SmartThings staff any word when 47.10 will be available for SmartThings Station users?
@Automated_House have your Eve Motion devices had any issue with sporadically going offline and not reconnecting? I have about 20 of these devices, and every few days a new device goes offline with the only fix being to remove the device, reset it and then re-add it back into SmartThings. I know it is not a signal strength issue as the latest Eve Motion to do this is 10 feet from my hub with a powered Thread repeater 6 feet away as well. I also have additional powered thread devices throughout my entire home (Eve Energy) acting as repeaters. I am a bit stumped and my only hope at this point is that version 3.2 fixes something that was causing this from the beta program Matter firmware version 3.1
yes, it would frequently go offline when on 3.1. However, it would come back after a power cycle (remove battery). It definitely seems better on 3.2. I can’t remember the last time it went offline after 3.2…
I still don’t know what Firmware version do I have on my Eve, but Illumance sensor is reporting good now, not sure if it was updated through the Station or it was updated while I connected temporary to Amazon. I don’t know how to see the firmware version of my Station neither.
Is there any update on new devices after this year?
I’d like to suggest the Aqara Door and Window Sensor P2 (WWST certified device and one of the very few native Matter over Thread sensors in the market) which according to CSA has a firmware update, version 1.0.1.1.
I don’t know what it fixes, but hopefully it will fix the battery reporting which is always 100% (and in stock drivers does not even appear but that’s probably a different issue). Although the battery percentage may be just normal, the CR123A battery has a quite flat discharge curve and since it’s supposed to last 2 or 3 years maybe it can’t detect the voltage drop yet.
There are a few more products from WWST partners with Matter OTA support like the ones from Aqara, for instance the P2 Motion Sensor which now supports sensitivity adjustment and unoccupied delay.
While there are workarounds to update them thanks to matter multi-admin they’re not as convenient as just pressing the “update” button.
IKEA has recently launched their new Matter over Thread line of products and there are already Matter OTA firmware updates available for products like the T&H sensor.
Will SmartThings be able to update them or is the list still restricted to those three Eve devices?
Edit: Looks like there are Matter OTA for IKEA devices even if they are not advertised
