Matter enabled smart lock
I should have clarified, how my existing Assure 2 deadbolt would adapt. Almost seems like I may need to buy a new one and pop the indoor part off? Seems like a pricy solution though.
Is there older model (which is not and add on form factor), compatible? There literature implies it is not ( Aqara Smart Lock U100, Fingerprint Keyless Entry Door Lock with Apple Home Key, Touchscreen Keypad, Bluetooth Electronic Deadbolt, IP65 Weatherproof, Supports Apple HomeKit, Alexa, Google, IFTTT, Gray - Amazon.com)?
Compatible with Matter? Compatible with SmartThings? Compatible with a UK multipoint lock? Or are you talking about a specific feature like the fingerprint reader? Not sure what you’re asking…:thinking:
There are definitely people using the U100 with SmartThings, as mentioned above. I believe that’s via Matter over Bridge, so you would need to have both a SmartThings/aeotec hub and an aqara hub that works as a matter bridge. In the good news, then the integration would be local.
@Automated_House
Sorry, I should have said compatible with ST using the V3 hub and matter. Application is to replace a US deadbolt. So unlike other Matter Integrations, the Agara hub would be required?
At the time of this posting, matter offers three protocol options:
  1. Matter over WiFi. No additional hub required.
  2. Matter over Thread. You must have at least one “thread border router“ in your home. There is one built into the v3 hubs and the Station, but not the V2.
  3. Matter over Bridge. This method allows an end device of a non-matter protocol, typically Zigbee or Bluetooth, to be brought in to a matter setup using a “matter bridge“ device typically provided by the end device manufacturer. Several of the aqara hubs are also matter bridges and can bridge many of their Zigbee devices into matter. The SwitchBot hub 2 is a matter bridge that can bring in many of its Bluetooth devices including its lock. And the Phillips hue hub is a matter bridge that can bring in many of its Zigbee devices, including some third-party Zigbee green power devices which would otherwise not be supported by SmartThings.
Aqara does have a few end devices which are individually certified for matter, typically using thread. But I believe at the time of this posting all of their locks except the U200 require a matter bridge to use matter.
BTW, aqara does have a couple of cameras which have hub capability and also act as matter bridges, if that’s of any interest. You can’t use the Camera function in the SmartThings app, but you can use it in its own app and stream it to an echo device. And it’s an IR blaster. This device is a perfect example of why I’m willing to go outside my existing ecosystem to get some specific features and use case solutions. :cat2:
Correct, U100 with SmartThings requires an Aqara bridge and for that bridge to have Matter bridge functionality enabled. This exposes U100 lock status, tamper status and battery to SmartThings. Lock codes have to be managed in the Aqara app (or Apple Home if you’re using that integration).
This is helpful to know. So Matter doesn’t fully matter (LOL). But I’m guessing you have to sort of figure this out from the radio method and listed connectability as they don’t explicitly state what approach each device is.using.
I have the Aqara U200 Smart Lock through the kickstarter.
It is not geared to any particular matter ecosystem it is a matter smart lock end-of.
You do not need the Aqara M3 hub as most settings are through the Aqara Home App when connected by bluetooth. Possibly the M3 is the only way to get some automations.
Users and codes can also be added through HK and ST, not sure about HA.
Euro, US and UK locks are supported.
Apple Homekey, Aqara Nfc and any Mifare Nfc are supported with support for Android Nfc coming soon.
Aqara Home App
ST App
Samsung Wallet
Alexa
Google Home
Installation and compatibility is shown here
I have the Aqara G4 Doorbell and the Aqara U200 Door Lock, in Smartthings you can get notified of a doorbell press, then see who it is and unlock the door, if you like them!
interesting! I had heard you could do that in the Aqara app, but didn’t know they also made it work in SmartThings.
I got the Aqara U200 today and setup in Homekit and the Aqara app, but in ST (Aeotec V3), I have no settings shown, only can lock/unlock…can’t add codes via SLGA, no battery indication, no tamper alert. It is on the Matter Lock ST Beta Driver. What am I missing? I have added it 3 times and it comes in the same way each time.
Hmm, that’s strange. There are no specific fingerprints for the Aqara so it should match on generic fingerprint based on deviceTypeId which defaults to the base-lock profile which supports:
  • lock/unlock
  • lockCodes
  • tamperalert
  • battery
  • firmware update
Check the assigned profile for the device in the ST Advanced Web App and also the deviceTypeId for the endpoints of the device in the API Browser+.
Also, check the timestamp on the lock driver and see if it has been updated recently. If it hasn’t, I’d suggest removing it from your hub and letting the production driver get installed during commissioning.
Same behavior with the stock production driver dated a week ago.
Device Profile
lock-lockalarm-nobattery
PresentationID
bbef9a4e-3d38-32b1-bc2d-f0d4364e7743
These are the only commands available.
Need to see the deviceTypeID for the endpoint(s) from the API Browser+ as well as the vendorID and productId.
|[{“endpointId”:0x00,“deviceTypes”:[{“deviceTypeId”:0x16}]},{“endpointId”:0x01,“deviceTypes”:[{“deviceTypeId”:0x0A}]},{“endpointId”:0x02,“deviceTypes”:[{“deviceTypeId”:0x11}]}]|
Vendor ID 0x115F
Product ID 0x2802
Well, this explains it. Sometime in the last month or so they added a specific fingerprint for both the Aqara U200 and U300 and mapped them to the lock-lockalarm-nobattery profile.
#Aqara
  - id: "4447/10242"
    deviceLabel: Aqara Smart Lock U200
    vendorId: 0x115F
    productId: 0x2802
    deviceProfileName: lock-lockalarm-nobattery
I’d file an issue against the driver here as well as open a support case.
done. thanks!
What should the profile be? What is yours set to?
I don’t have that particular lock, but if you are able to create/delete lock codes, get battery level, and tamper alerts from other Matter controllers, then I would expect it to map to the base-lock profile which has those capabilities as I mentioned earlier.
gotcha…when I read those words yesterday, I didn’t make the connection. :wink:
