Then perhaps it is his drivers that are not playing nicely with some update that smartthings pushed.
EDIT: Investigated issue 2. A slow response/reaction time:
2023-06-18T17:11:46.173178518+00:00 TRACE frient Motion Received event with handler zigbee
2023-06-18T17:11:46.174459491+00:00 INFO frient Motion <ZigbeeDevice: 6e577da2-b8af-438f-bd4e-86b7b35ef85e [0x2457] (Kitchen Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2457, src_endpoint: 0x22, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OccupancySensing >, lqi: 0xBA, rssi: -85, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Bitmap8, Occupancy: Occupancy[0x01] > > > >
2023-06-18T17:11:46.191969909+00:00 TRACE Virtual Devices V2 Received event with handler capability
2023-06-18T17:11:46.192841011+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> received command: {"capability":"switch","args":{},"command":"off","component":"main","positional_args":{}}
2023-06-18T17:11:46.200588549+00:00 TRACE Virtual Devices V2 Found CapabilityCommandDispatcher handler in vedgeDriver
2023-06-18T17:11:46.209579709+00:00 INFO Virtual Devices V2 Virtual switch turned >> off <<
2023-06-18T17:11:46.210862350+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"off"},"attribute_id":"switch","capability_id":"switch"}
2023-06-18T17:11:46.667136374+00:00 TRACE Zigbee Switch Received event with handler zigbee
2023-06-18T17:11:46.690354310+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CA8, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xBC, rssi: -85, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x05, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-06-18T17:11:46.692200900+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"closed"},"attribute_id":"contact","capability_id":"contactSensor"}
2023-06-18T17:11:46.693938101+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:46.740751163+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:46.743231069+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 9 datatype 2
2023-06-18T17:11:46.773053639+00:00 TRACE frient Motion Found ZigbeeMessageDispatcher handler in zigbee-motion
2023-06-18T17:11:46.780882552+00:00 INFO frient Motion Executing ZclClusterAttributeValueHandler: cluster: OccupancySensing, attribute: Occupancy
2023-06-18T17:11:46.809478843+00:00 INFO frient Motion <ZigbeeDevice: 6e577da2-b8af-438f-bd4e-86b7b35ef85e [0x2457] (Kitchen Motion Sensor)> emitting event: {"state":{"value":"active"},"component_id":"main","capability_id":"motionSensor","attribute_id":"motion"}
2023-06-18T17:11:46.813219379+00:00 DEBUG frient Motion Kitchen Motion Sensor device thread event handled
2023-06-18T17:11:47.002937524+00:00 DEBUG Virtual Devices V2 vEdge Living Room Presense device thread event handled
2023-06-18T17:11:47.009548161+00:00 TRACE Virtual Devices V2 Received event with handler capability
2023-06-18T17:11:47.104619339+00:00 TRACE Zigbee Switch Found ZigbeeMessageDispatcher handler in zigbee_switch
2023-06-18T17:11:47.105844952+00:00 INFO Zigbee Switch Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-06-18T17:11:47.152106404+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> emitting event: {"component_id":"main","capability_id":"switch","state":{"value":"on"},"attribute_id":"switch"}
2023-06-18T17:11:47.208060034+00:00 TRACE frient Motion Received event with handler zigbee
2023-06-18T17:11:47.295698164+00:00 INFO frient Motion <ZigbeeDevice: b7a55348-c74d-4e8b-868e-0e2b7e848c50 [0xD028] (Motion Sensor Hallway)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD028, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xC4, rssi: -79, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x22, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0020, DataType: Uint8, BatteryVoltage: 0x1E >, < AttributeRecord || AttributeId: 0x003E, DataType: Bitmap32, BatteryAlarmState: 0x00000000 > > > >
2023-06-18T17:11:47.323022153+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 9 9 nil [string "st/device.lua"]:121: attempt to index a nil value (local 'component') nil
2023-06-18T17:11:47.340221415+00:00 INFO Personal Tuya Devices - main Datapoint negative. -9
2023-06-18T17:11:47.341435688+00:00 DEBUG Personal Tuya Devices - main Presense Sensor Billiard Room device thread event handled
2023-06-18T17:11:47.342652296+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:47.343818546+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: d39a5edc-0f4d-44fa-9ad5-f15277ca0605 [0x1903] (Presense Sensor PC Corner)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x1903, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0xD0, rssi: -46, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x60, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x00E3 (BE), < DatapointSegment || dpid: 0x6D, DatapointSegmentType: Value, length: 0x0004 (BE), value: 0x00000000 (BE) > > > >
2023-06-18T17:11:47.562799982+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> received command: {"capability":"switch","args":{},"command":"on","component":"main","positional_args":{}}
2023-06-18T17:11:48.169308752+00:00 TRACE Virtual Devices V2 Found CapabilityCommandDispatcher handler in vedgeDriver
2023-06-18T17:11:48.191746298+00:00 INFO Virtual Devices V2 Virtual switch turned >> on <<
2023-06-18T17:11:48.195418800+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"on"},"attribute_id":"switch","capability_id":"switch"}
2023-06-18T17:11:48.638660310+00:00 DEBUG Zigbee Switch Coaster hallway device thread event handled
2023-06-18T17:11:48.640573600+00:00 TRACE Zigbee Switch Received event with handler zigbee
2023-06-18T17:11:48.658613282+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CA8, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xBC, rssi: -83, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xB3, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-06-18T17:11:48.675473374+00:00 TRACE frient Motion Found ZigbeeMessageDispatcher handler in zigbee-motion
2023-06-18T17:11:48.722574246+00:00 INFO frient Motion Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
2023-06-18T17:11:48.792221386+00:00 INFO frient Motion <ZigbeeDevice: b7a55348-c74d-4e8b-868e-0e2b7e848c50 [0xD028] (Motion Sensor Hallway)> emitting event: {"state":{"value":100},"component_id":"main","capability_id":"battery","attribute_id":"battery"}
2023-06-18T17:11:48.809325934+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"open"},"attribute_id":"contact","capability_id":"contactSensor"}
2023-06-18T17:11:48.825384959+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:48.826651259+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:48.879317245+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 109 datatype 2
2023-06-18T17:11:48.880641574+00:00 DEBUG Hue Motion Sensor driver device thread event handled
2023-06-18T17:11:48.881856848+00:00 DEBUG Ikea Styrbar Remote driver device thread event handled
2023-06-18T17:11:48.920245032+00:00 DEBUG Virtual Devices V2 vEdge Living Room Presense device thread event handled
2023-06-18T17:11:48.930548848+00:00 DEBUG Zigbee Sensors Edge Driver [YG] 1.8.16 driver device thread event handled
2023-06-18T17:11:49.170323676+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> received command: {"capability":"switch","args":{},"command":"off","component":"main","positional_args":{}}
2023-06-18T17:11:49.480363619+00:00 TRACE Virtual Devices V2 Found CapabilityCommandDispatcher handler in vedgeDriver
2023-06-18T17:11:49.550087797+00:00 INFO Virtual Devices V2 Virtual switch turned >> off <<
2023-06-18T17:11:49.552321913+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"off"},"attribute_id":"switch","capability_id":"switch"}
2023-06-18T17:11:49.554295900+00:00 DEBUG frient Motion Motion Sensor Hallway device thread event handled
2023-06-18T17:11:49.557770636+00:00 DEBUG frient Motion driver device thread event handled
2023-06-18T17:11:49.781632178+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"closed"},"attribute_id":"contact","capability_id":"contactSensor"}
2023-06-18T17:11:49.825415392+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 109 109 nil [string "st/device.lua"]:121: attempt to index a nil value (local 'component') nil
2023-06-18T17:11:49.880590632+00:00 INFO Personal Tuya Devices - main Datapoint negative. -109
2023-06-18T17:11:49.924401527+00:00 DEBUG Personal Tuya Devices - main Presense Sensor PC Corner device thread event handled
2023-06-18T17:11:49.925668160+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:49.926866425+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: 540595a6-eea4-450e-9bd1-b65ecd33038d [0xBFFE] (Presense Sensor Billiard Room)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBFFE, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0xB2, rssi: -84, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x10, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x00CD (BE), < DatapointSegment || dpid: 0x09, DatapointSegmentType: Value, length: 0x0004 (BE), value: 0x00000100 (BE) > > > >
2023-06-18T17:11:49.990961123+00:00 TRACE Zigbee Switch Found ZigbeeMessageDispatcher handler in zigbee_switch
2023-06-18T17:11:49.992973462+00:00 INFO Zigbee Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-06-18T17:11:50.060713649+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> emitting event: {"component_id":"main","capability_id":"switch","state":{"value":"on"},"attribute_id":"switch"}
2023-06-18T17:11:50.090628599+00:00 DEBUG Virtual Devices V2 vEdge Living Room Presense device thread event handled
2023-06-18T17:11:50.364238002+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:50.486837604+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:50.519586304+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 9 datatype 2
2023-06-18T17:11:50.620540422+00:00 DEBUG Zigbee Switch Coaster hallway device thread event handled
2023-06-18T17:11:50.659655303+00:00 TRACE Zigbee Switch Received event with handler zigbee
2023-06-18T17:11:50.663689986+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CA8, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xBE, rssi: -81, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xB4, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-06-18T17:11:50.955510157+00:00 TRACE Zigbee Switch Found ZigbeeMessageDispatcher handler in zigbee_switch
2023-06-18T17:11:51.004849148+00:00 INFO Zigbee Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-06-18T17:11:51.022810124+00:00 INFO Zigbee Switch <ZigbeeDevice: 1bb21603-e391-4e2a-9a64-96976ef89cdb [0x6CA8] (Coaster hallway)> emitting event: {"component_id":"main","capability_id":"switch","state":{"value":"on"},"attribute_id":"switch"}
2023-06-18T17:11:51.084919163+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 9 9 nil [string "st/device.lua"]:121: attempt to index a nil value (local 'component') nil
2023-06-18T17:11:51.085807940+00:00 INFO Personal Tuya Devices - main Datapoint negative. -9
2023-06-18T17:11:51.087008207+00:00 DEBUG Personal Tuya Devices - main Presense Sensor Billiard Room device thread event handled
2023-06-18T17:11:51.088198802+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:51.152507273+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: 540595a6-eea4-450e-9bd1-b65ecd33038d [0xBFFE] (Presense Sensor Billiard Room)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBFFE, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0xBE, rssi: -82, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x11, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x00CE (BE), < DatapointSegment || dpid: 0x09, DatapointSegmentType: Value, length: 0x0004 (BE), value: 0x00000110 (BE) > > > >
2023-06-18T17:11:51.220899786+00:00 DEBUG Zigbee Switch Coaster hallway device thread event handled
2023-06-18T17:11:51.263368009+00:00 TRACE Zigbee Switch Received event with handler capability
2023-06-18T17:11:51.313944618+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:51.333769859+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:51.353784195+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 9 datatype 2
2023-06-18T17:11:51.541603724+00:00 INFO Zigbee Switch <ZigbeeDevice: 4dcac771-2df0-414c-b7b1-61759926da8f [0xB587] (Bijkeuken lamp)> received command: {"capability":"switch","component":"main","command":"on","args":{},"positional_args":{}}
2023-06-18T17:11:51.571412621+00:00 TRACE Zigbee Switch Found CapabilityCommandDispatcher handler in zigbee_switch -> ZLL Dimmer Bulb
2023-06-18T17:11:51.572647238+00:00 INFO Zigbee Switch <ZigbeeDevice: 4dcac771-2df0-414c-b7b1-61759926da8f [0xB587] (Bijkeuken lamp)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB587, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2023-06-18T17:11:51.661388920+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 9 9 nil [string "st/device.lua"]:121: attempt to index a nil value (local 'component') nil
2023-06-18T17:11:51.680134955+00:00 INFO Personal Tuya Devices - main Datapoint negative. -9
2023-06-18T17:11:51.698892996+00:00 DEBUG Personal Tuya Devices - main Presense Sensor Billiard Room device thread event handled
2023-06-18T17:11:51.728545482+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:51.751107424+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: 6542bb7d-cab0-4dfa-beaa-a5500f3bee8b [0x9EE1] (Presense Sensor Living Room)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x9EE1, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0xCE, rssi: -70, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x7A, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x0020 (BE), < DatapointSegment || dpid: 0x01, DatapointSegmentType: Enum, length: 0x0001 (BE), value: 0x00 > > > >
2023-06-18T17:11:51.791864792+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:51.792727557+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:51.840514438+00:00 INFO Personal Tuya Devices - main Default datapoint 1 0
2023-06-18T17:11:52.052850220+00:00 DEBUG Zigbee Switch Bijkeuken lamp device thread event handled
2023-06-18T17:11:52.090569737+00:00 TRACE Zigbee Switch Received event with handler capability
2023-06-18T17:11:52.091855713+00:00 INFO Zigbee Switch <ZigbeeDevice: 83df0323-f994-4a8b-9575-72d5b4a4c9c4 [0xA867] (Keuken Led Strip)> received command: {"capability":"switch","component":"main","command":"on","args":{},"positional_args":{}}
2023-06-18T17:11:52.110707801+00:00 TRACE Zigbee Switch Found CapabilityCommandDispatcher handler in zigbee_switch
2023-06-18T17:11:52.217239374+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: 6542bb7d-cab0-4dfa-beaa-a5500f3bee8b [0x9EE1] (Presense Sensor Living Room)> emitting event: {"component_id":"main","attribute_id":"presence","state":{"value":"not present"},"capability_id":"presenceSensor"}
2023-06-18T17:11:52.275566856+00:00 DEBUG Zigbee Switch Keuken Led Strip device thread event handled
2023-06-18T17:11:52.309260361+00:00 DEBUG Zigbee Switch Bijkeuken lamp device thread event handled
2023-06-18T17:11:52.310585357+00:00 DEBUG Zigbee Switch driver device thread event handled
2023-06-18T17:11:52.507751557+00:00 INFO Personal Tuya Devices - main Additional event... 1 1 contactSensor
2023-06-18T17:11:53.059821121+00:00 TRACE Virtual Devices V2 Received event with handler capability
2023-06-18T17:11:53.063513966+00:00 WARN Personal Tuya Devices - main Attempted to generate event for 6542bb7d-cab0-4dfa-beaa-a5500f3bee8b.main but it does not support capability Contact Sensor
2023-06-18T17:11:53.066142280+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 1 1 nil false Attempted to generate event for 6542bb7d-cab0-4dfa-beaa-a5500f3bee8b.main but it does not support capability Contact Sensor
2023-06-18T17:11:53.155253146+00:00 INFO Personal Tuya Devices - main Datapoint negative. -1
2023-06-18T17:11:53.184860276+00:00 DEBUG Personal Tuya Devices - main Presense Sensor Living Room device thread event handled
2023-06-18T17:11:53.186230294+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:53.187434562+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: d39a5edc-0f4d-44fa-9ad5-f15277ca0605 [0x1903] (Presense Sensor PC Corner)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x1903, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0xCE, rssi: -46, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x61, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x00E4 (BE), < DatapointSegment || dpid: 0x6D, DatapointSegmentType: Value, length: 0x0004 (BE), value: 0x00000000 (BE) > > > >
2023-06-18T17:11:53.232144906+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> received command: {"capability":"switch","args":{},"command":"off","component":"main","positional_args":{}}
2023-06-18T17:11:53.245381521+00:00 TRACE Virtual Devices V2 Found CapabilityCommandDispatcher handler in vedgeDriver
2023-06-18T17:11:53.246680170+00:00 INFO Virtual Devices V2 Virtual switch turned >> off <<
2023-06-18T17:11:53.263339829+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"off"},"attribute_id":"switch","capability_id":"switch"}
2023-06-18T17:11:53.380766180+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:53.425178375+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:53.426969937+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 109 datatype 2
2023-06-18T17:11:53.428163867+00:00 INFO Virtual Devices V2 <Device: 5388c003-a5c6-4843-b0e6-ed4a4925ebf8 (vEdge Living Room Presense)> emitting event: {"component_id":"main","state":{"value":"closed"},"attribute_id":"contact","capability_id":"contactSensor"}
2023-06-18T17:11:53.493067636+00:00 DEBUG Virtual Devices V2 vEdge Living Room Presense device thread event handled
2023-06-18T17:11:53.859840598+00:00 WARN Personal Tuya Devices - main Unexpected component for datapoint 109 109 nil [string "st/device.lua"]:121: attempt to index a nil value (local 'component') nil
2023-06-18T17:11:53.874268141+00:00 INFO Personal Tuya Devices - main Datapoint negative. -109
2023-06-18T17:11:53.875527437+00:00 DEBUG Personal Tuya Devices - main Presense Sensor PC Corner device thread event handled
2023-06-18T17:11:53.876730038+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-06-18T17:11:53.929746200+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: 540595a6-eea4-450e-9bd1-b65ecd33038d [0xBFFE] (Presense Sensor Billiard Room)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBFFE, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0x80, rssi: -89, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x12, ZCLCommandId: 0x02 >, < DataReportClient || transid: 0x00CF (BE), < DatapointSegment || dpid: 0x09, DatapointSegmentType: Value, length: 0x0004 (BE), value: 0x00000112 (BE) > > > >
2023-06-18T17:11:53.968815391+00:00 INFO Zigbee Switch <ZigbeeDevice: 4dcac771-2df0-414c-b7b1-61759926da8f [0xB587] (Bijkeuken lamp)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB587, dest_endpoint: 0x03, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2023-06-18T17:11:54.110426828+00:00 INFO Zigbee Switch <ZigbeeDevice: 4dcac771-2df0-414c-b7b1-61759926da8f [0xB587] (Bijkeuken lamp)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB587, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2023-06-18T17:11:54.121587406+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-06-18T17:11:54.122913068+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataReportServer
2023-06-18T17:11:54.141472677+00:00 WARN Personal Tuya Devices - main Datapoint not found. Using default 9 datatype 2
2023-06-18T17:11:54.146565555+00:00 INFO Zigbee Switch <ZigbeeDevice: 4dcac771-2df0-414c-b7b1-61759926da8f [0xB587] (Bijkeuken lamp)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB587, dest_endpoint: 0x03, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0007 > > >
2023-06-18T17:11:54.218725284+00:00 DEBUG Zigbee Switch Bijkeuken lamp device thread event handled
The devices in the kitchen are called “keuken” because that’s dutch for kitchen.
Using the search function, i can indeed find that a full 5 seconds passed before the automation was executed here, normally it’s a half second before the automation is executed.
But i can’t seem to find out why it was delayed at that time.
