LOL…wouldn’t it be a virtual flu?
Here’s the code for the one I use.
* Virtual Contact Sensor Switch
* Copyright 2017 Wesley Stocker
* ON == Open
* OFF == Closed
metadata {
definition (name: "Virtual Contact Sensor Switch", namespace: "ph4r", author: "Wesley Stocker") {
capability "Actuator"
capability "Contact Sensor"
capability "Relay Switch"
capability "Sensor"
capability "Switch"
command "onPhysical"
command "offPhysical"
command "open"
command "close"
simulator {
status "open": "contact:open"
status "closed": "contact:closed"
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "off", label: '${currentValue}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
state "on", label: '${currentValue}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00A0DC"
standardTile("on", "device.switch", decoration: "flat") {
state "default", label: 'On', action: "onPhysical", backgroundColor: "#ffffff"
standardTile("off", "device.switch", decoration: "flat") {
state "default", label: 'Off', action: "offPhysical", backgroundColor: "#ffffff"
standardTile("contact", "device.contact", width: 2, height: 2) {
state("closed", label:'${name}', icon:"st.contact.contact.closed", backgroundColor:"#00A0DC", action: "open")
state("open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#e86d13", action: "close")
main "switch"
details(["switch","on","off","contact"])
def pair = description.split(":")
createEvent(name: pair[0].trim(), value: pair[1].trim())
def open() {
log.trace "open()"
sendEvent(name: "switch", value: "on")
sendEvent(name: "contact", value: "open")
def close() {
log.trace "close()"
sendEvent(name: "switch", value: "off")
sendEvent(name: "contact", value: "closed")
def on() {
log.debug "$version on()"
def off() {
log.debug "$version off()"
def onPhysical() {
log.debug "$version onPhysical()"
sendEvent(name: "switch", value: "on", type: "physical")
def offPhysical() {
log.debug "$version offPhysical()"
sendEvent(name: "switch", value: "off", type: "physical")
private getVersion() {
"PUBLISHED"
