I have been having a bear of a time with Zigbee, too. I have a case open but as soon as I complain about it, it works, again, and then when I tell them it is working, everything screws up again.
I have a 3 windows and a door using the Smartthings Multi-sensor and a leak sensor I bought from the Smartthings web site that stop responding during the day. If I look at the “recently” in the app, I see that they work for brief periods of time during the day and stop, later. One window is in the very same room as the hub, and my WiFi access point, which is on the opposite side of the room. The window is on the wall adjacent to them, so I cannot think WiFi is interfering with that. Another one is in a bedroom next to that room. The other is down the hall. The moisture sensor is in the basement near the water heater and the door is in a detached garage and I am using an IRIS 3210 as a repeater.
I also have two of the dimmer/smart outlets from the Smartthings web site controlling my living room lights. They report what they are doing but when this strange occurrence happens, you cannot control them or one of them. It knows it is off or on but you cannot turn it off or on through the app. It just sits at “turning on” or “turning off”.
I know Zigbee runs at 2.4GHz, which is what 802.11B/G/N routers use, as well as your microwave oven but my access point switches channels if it sees interference and it has not switched channels. Sure, I could turn off my 802.11B radio on my AP but so many things, like my Ecobee4 thermostat and Nest smoke/CO detectors require it. Plus, A-Band does not have the range.
The problem seems to happen when I add or remove devices and lasts a few days and then magically goes away. It is so bad, I am beginning to not be a fan of Zigbee. I rebooted my hub, today, and enabled it to update Zigbee firmware hoping that it will help but it looks like everything is up to date at 0x00000019.
I cannot help think it is a Zigbee problem in the hub or in the cloud. I know the battery operated sensors probably do not repeat but my dimmer downstairs, which I have had no problems with, and my two living room lamp dimmers are plugged in and I have to think they repeat the signal, with the IRIS 3210 I have just outside in a weather proof outlet box. So, some repeating is going on.
