M5 ZigBee cc2630
I’m trying to install without success this device (M5 ZigBee CC2630) in my hub. Any edge driver needed for this device?
Thanks, Eric
I’m confused. Isn’t that a zigbee coordinator? If so, the Zigbee profiles that smartthings uses only support one coordinator per network. You would be using the device you linked to instead of a smartthings/Aeotec hub. Not connected to one.
Did you have it working before? And if so, with which DTH? Maybe it’s downgradeable to a router, but the documentation was only available in Chinese, so I wasn’t sure.
