Lutron, Lutron Aurora, Matter, and SmartThings Questions
Today’s random thoughts about Matter:
-Lutron. What is you doin? The entirety of my lighting (besides a couple one-off govee devices - but that company is another issue entirely) are now working over Matter. Except Lutron. And yes they have good standard integrations with nearly all platforms already. I realize that. But I was trying to run all my lighting through Aqara as they seem to have the most robust automation system.
-ok one other light. Eve Flare. As they have gradually rolled out Matter to existing products, this is one item that seems to have been left behind. And I don’t get it. Seems like one of the easiest to do.
-still wish someone would put out a generic zigbee hub that would take connected devices and expose them to Matter (those devices which are currently part of the Matter standard, that is). I guess it’s a big ask.
Background: I have hue hub (which is “full” for some reason), aqara hub, and ikea hub. Plus a mishmash of other devices which I’m currently running on zigbee2mqtt. The ikea stuff could be consolidated to the zigbee2mqtt network but I like that the lights come through over Matter using the hub. I don’t want to run the zigbee2mqtt network anymore. Maybe I need to reconsider smartthings as I have really only been using it with Matter since firing it back up.
Does the lutron aurora work with SmartThings and can I use the hub to directly bind it to the respective bulbs?
Ok that’s all for now.
Since the question that’s likely to get the most responses is the one about a non-matter device, the Luton aurora, I’ve moved that to a new thread for you. If you want to repost just the matter related stuff to the matter thread, go ahead.
As far as I know, it will only work with SmartThings when connected to a Hue bridge. I believe these are now exposed through the official Hue/SmartThings integration, but I’m not 100% sure. They are definitely exposed through the custom integration that @blueyetisoftware created. And I think they also come in through the matter over bridge integration, but it’s limited integration.
Very interesting. Though it’s not super clear, the Aurora is a zigbee device. Wonder if it would be as simple as creating a driver. Don’t know anything about that though.
Thanks for the reply and you are probably right to separate the long rant I posted :slightly_smiling_face:
If it were that simple, somebody would’ve done it already. :wink:
It might be possible, it might not. There are lots of reports on other forums that these specific devices only work with some Zigbee controllers. There are a lot of technical reasons for that, but the short answer is they have only certified them to work with the Hue Bridge so it’s a matter of luck if they work with some other brand.
See the following extensively detailed discussion:
Good stuff, thanks.
The aurora thing isn’t a deal breaker as I know you can bind them directly to the bulbs you want to control and just not pair the aurora to any hub.
I had them setup this way awhile back but I didn’t find it as reliable as initiating a binding using a hub.
But it’s interesting to think about and I’m also going to look more into the Moes hub you mentioned.
I thought I would bump this up again. Is there a way, or does someone have an edge driver to connect these directly to SmartThings? I am using the KOF Ceiling Fan and would love to be able to use this with the fan. Right now through Hue I can’t make it do “nothing” and then do something in SmartThings, which would also be cool.
Thanks - sorry I wasn’t clear. KOF was King of Fans, so I am using that driver. I can control everything through SmartThings but everyone keeps turning off the switch. I thought about just removing the sewitch but I would rather have a button that can be used that takes the place of the switch. The Lutron is great because you don’t have to replace anything. It just attaches to the lightswitch.
I am trying to figure out a way but it sounds like there isn’t. Going to keep looking to see if there is something else. Maybe Aeotec has something themselves.
