I use a STv2 hub and Lutron Bridge Pro together. I have my STv2 hub set up to turn off all my lutron caseta dimmers when I am watching a movie, however when I have it set to turn them back on after the movie they default to 100% brightness. Is there a way to save and restore whatever levels the dimmers are on prior to them being turned off to come back on to?
When you say you have them “set to turn back on” can you use a scene in that automation? Then you could have them come on to A specific level.
If you want to save the previous level and then return to it without knowing what the level was at the time you wrote the automation, you would need to use webcore.
