My experience says “no.” (And not sure if you saw this, but despite the fact that DTH mentinons “Aurora,” that is the name of a company who makes a different product that this DTH was apparently written to include.)
With the stock DTHs, it joins as a Thing (so no fingerprint matches). I haven’t tried on ST, but on Hubitat it’s similar, and I’m able to get it to work with a custom driver (DTH in ST land) that I threw together. Unfortunately, the device doesn’t seem to work like I’d want, which ideally would be something like a button/scene device that sends different events for left and right turns or perhaps and event when a turn starts and a turn stops or different events for different turn speeds. Instead, it seems to remember a built-in level from 0-254, then turning the knob continually sends that level back to the hub. Pressing the button also sends an event. That’s the most usable part of the device; the other seems like it might be workable if you “bind” it to a real dimmer, though maybe it’s possible to send a command to the device to set its level should you adjust the device instead of the dimmer (I don’t know enough about Zigbee to know if this works). As-is, I think it’s a little odd. A Zigbee expert will undoubtedly create a better driver/DTH, however, so I’m sure the device is capable of working a little better with someone who knows what they’re doing.
They can also be paired directly to bulbs. The manual, unsurprisingly, only mentions pairing directly to a bulb or pairing to a Hue network that contains a Hue Bridge. Since ZLL is supposed to fall back to ZHA, I’m assuming that’s why this still pairs to ST and Hubitat, so hopefully it can be made to work in some capacity.
