FAQ: Full list of buttons and remotes confirmed to work with SmartThings
I’d like to know which buttons and remotes are currently supported or might be supported in the future. Ideally, I’d like to find something similar to the following:
http://www.evolvecontrols.com/devices/control-devices/glass-series
Though alternatively just a simple nice-looking button which actually works unlike this Aeon according to Amazon reviews:
There is an Aeon Key Fob as well, but it doesn’t seem to be very durable or stylish:
What else is available?
Wireless, Battery Operated Wall Switch
I need a panic button
Lutron Connected Bulb Remote
Idea in place of a switch for lights
Using "Hello Home" Phrases with Amazon Echo?
A Simple Remote On/Off Switch?
Z-Wave Multi Button Device Suggestion?
Wall Keypads?
Arm / disarm alarm with button
Switch Control Button that looks like a switch?
Wall Switch Controlling Multiple Lamps?
FAQ: How to add a second wall dimmer without wiring?
Get rid of 3 way lights?
Iris Smart Button
Remote Control or Wall Switch
Wireless battery powered switch
Light switches that only send signal to Smart things
Battery-powered switches and dimmer switches
Zwave panic button?
Iris Smart Button
Fibaro FGPB-101-1 US The Button, Z-Wave Scene Controller
Grouping lights to switch?
Wall switch/remote for LIFX?
Nexia One Touch
What to put in place of switches when using Smart Lights?
Micro dimmer that works with a fan
Looking for a switch with scene buttons
Flic Button Alternatives
Newbie Question: Can I control a plug-in module with a switch that isn't wired to the outlet?
Wall switch without wiring
Arming and disarming other than by phone or tablet
GE Jasco Z-wave Smart Remotes (CES 2017)
Osram/Sylvania Lightify (it works)
Single button controller / Iris SmartButton alternative
Door bell button?
Remote or KeyFob to Arm/Disarm?
Retrofit 3-way
SmartThings In Wall Scene Controller?
Bedside lamp dimmer
How to keep circuits to smartbulbs always "on"
[COMPLETE] Sliding Door electronic lock with Keypad access, fully ST integrated
Controlling Leviton outlet module from stand alone switch or button
Single Push Button Battery Operated Switch
Who makes the BEST Z-Wave dimmer? (Leviton, GE, Linear, Cooper)
What do I call this and where do I get one? One button z-wave controller?
Having trouble adding lights to GE 45600 after migration to v2
Thoughts on my smart home project
What's the difference between these two Hue kits?
SmartHomeMonitor - without pin keypad?
Doorbell in UK
Can a Z-Wave Remote control Zigbee Devices via SmartThings?
Lowe's Iris Sensors (New CentraLite models)
No Neutral, Outlets ok?
ISO battery powered switch
Moving from Wink to SmartThings--which devices will transfer?
Smart Lamp
3 Light switches in a single gang box?
Go Button (Wifi Connected Button)
Is there a load sensing in-wall receptacle?
Smart power strips and operation thereof
VFAQ: Lighting Control Options for UK SmartThings
Controlling Zigbee Bulb with Z-Wave Switch
Non video connected doorbell
Hardware inputs to trigger routines
Zigbee Blubs with status update
Looking for Recommended Switches for U.K. under £20 instead of Hue Dimmer
Does smartthings have lightswitches that are remotes?
Smart chime (not video doorbell)
4-way switching without a neutral between Master and Auxilary?
Google Home + SmartThings project idea + help
ZigBee 3-Way switch install
Multiple Light Switches For One Light Fixture - Which To Use?
[Alpha] Lutron Connected Bulb Remote
Power Allowance Issue , cant turn bulb back on with normal light switch after power allowance shuts it off
HomeSeer HS-WD100+ and more (Simple DTH in post 27, advanced feature DTH in post 32)
Suggest a Device
Push buttons to select light scene for Lifx bulbs?
Smart Switches
New to Echo and SmartThings - First project in new construction
Light remote control - what are my options
Smartthings alternative to SkylinkHome "Anywhere" Switch
Newbie here...basic question
Multiple Lighting Systems with ST (new to this game but loving it)
Any switches similar to an Insteon Keypad?
Z-Wave Stand Alone Wall Switch Remote
CES 2017 (general discussion thread)
Innovelli Smart Switch vs GE Z-Wave 14292
New to home automation -- How limited am I by old wiring?
Quick & dirty three-way switch w/two iris buttons & a bulb. Why not?
Using Motion Sensor as a light switch toggle?
Suggest a Device
ST equivalent to the Hue Dimmer Switch/Remote?
Z-Wave Aeon Labs Panic Button with Z-Wave Extender/Repeaters
Buzzing open a fail secure door strike via z-wave switch?
Virtual Switch + Secondary Controllers instead of 3-way traveler?
Need help with ideas on how to control separate lights in different rooms all on the same switch
Finding the right hardware for Lighting Control in two rooms
Is there a button press device I can add?
Is there a SmartApp to create and trigger lighting scenes?
Logitech Pop Button
Logitech Pop Button
Iris Smart Button
Multi zone switch... I'm new
Trying to Connect a Relay Switch to a Light Fixture with Old Wiring
Battery wall light switch?
Anyone have Smartthings with Roommates Living in the House
Aeotec WallMote Gen 5 - new device for 2016
Dimmers that can be disabled/enabled?
Minimote Headache
Looking for a virtual switch(three way switch hack)
Amazons releases Dash Buttons in the uk
Detecting if a HUE lamp connected through the HUE hub is unpowered
Duplex wall switches
Wall mounted buttons/scene controllers: any options?
A Short Intro to Scheduling/Device Control/Rules in SmartThings Classic
GE/Jasco 45631 Keypad/Controller
Light Switches - where to start? (UK)
Hue Dimmer Switch Connected to ST
Creating a 'Virtual Switch' to Operate an Outlet
ZWN-SC7 Enerwave 7 Button Scene Controller
Bedside table lamps and wall switch conundrum
GE 45631 with Aeotec Switch?
Older Leviton devices
How to control1 light fixture with 3 remotes
Working List of Items for Projects
Fear of Commitment! Lights and Google Home
Battery light switch
Best keyfob to use with SmartThings?
Smart lighting suggestions needed for basement project with RGBW lights
New Smartthings user, love it, few questions for ya on use as a security system
Change 3 way switch to 4 way with smart dimmers
Wireless lightning control (battery-operated wall switch)?
Does the Cooper RF9500 switch have to connect to another switch?
Handi-capable
Aspire rfwc5 device type?
Is there a device handler for the Z-Wave Nodon Soft Remote?
Help with outlet/dimmer
GE Zwave Fan Switch and Phillip Hue bulb
What do you like and use for scene control?
Bulbs, switches and sensors, oh my....what to buy (device class features FAQ)
Building New Home - Final Call for Thoughts
One rocker button switch
Compatible Bulbs/Switches?
Best wall switch option - EU user
Light Switches, and scene switches options (240v)?
3-way switch with only one switch having neutral wire
Flic button
Looking for a battery powered wireless switch that I can mount on a wall to control Leviton switch
Home monitoring: auto turn off for kids via garage door?
Using physical switch on a table lamp with a smart bulb?
Do I need a Lutron Smart Bridge to use their Pico switch with a nonLutron light?
Hue switch, to control Wemo socket
One lamp to controll others
Momentary switch - return to central positon
Will GE Dimmable Switch and Caseta Wireless work together in a 3-way switch setting?
Looking for device suggestions: RGBW Wall Switch and Fan/Light switch
Iris smart fob
Light switch recommendation for virtual 3-way with battery-powered auxiliary?
Looking for recommendation on outlets and button to control them
Wireless on/off button for Lightify flex
An easy button for the most annoying bugs
[ALPHA] Hue Dimmer Switch (ZHA) (beta) (no hue bridge)
Full gut renovation, need advice/experience of smartthings veterans
Switch to control 3 separate outlets?
Osram remote?
Trying to dim exterior lights vis GFI outlet
GE 45633 with SmartThings
Noob Q: Switch and bulb on separate circuits
Anyone know of a discreet switch
Light switch to run Smartthings Routines?
Good wireless light switch
One physical light switch to control a separate smart switch?
Hand held remote-Yes or no
Integrating Countdown Timer Switch (Enerlites HET06A)
Using GE 45600 with multi endpoint device?
Battery powered z-wave rocker remote
Where to buy ZWN-SC7 Enerwave 7 Button Scene Controller?
In-wall relays - what switchs are you using?
Improved Fibaro Button DH
Cooper Aspire Scene Controller RFWC5 and RFWC5D Device Handler [beta release]
Still Cannot Find Perfect Dimmer Switch
Corded devices to ST (Finland)
Physical color controller for Hue Lights
Advice on what to use: All On Switch to control a group of other switches?
Just a Button? 1 button, nothing more fancy?
ST and hue switch
Flic button
Smart Home Monitor - Feature Requests
Is the Lutron SeeTouch supported?
FAQ: All in one place--is there a single comprehensive list of all Devices that work with SmartThings?
Looking for Light Switch w/UI Separtaed from Switching
Official Support for Scene Controllers
Control smart bulbs without app?
Official Lutron Caseta Support in SmartThings (Beginning March 2017)
Grouping switches together
4 gang switch options?
Need help with a switch
CHEAP wireless switch to control smart bulb?
SmartThings Multipurpose Sensor turn on room lights?
In-Wall Leviton Switches or 4-Button Zone Controllers as "Controllers" (Remotes or Transmitters)
How to wire switch with no load
SOLVED: In search of simple wireless wall light switch
Light switches to control hue lights. (UK)
No neutral wire -> rewire fixture and switch for smart bulb + smart switch?
GE Add-On switch for under cabinet lights?
[BETA] Hue Accessories and rooms using Hue Bridge (TAP, Motion Sensor, Dimmer Switch)
Battery-operated Dimmer Switch recommendation?
Dimmer switch with desktop remote
Advice in Switches/Dimmers?
Wireless Z-wave button?
Making the case for going full blown home automation
Best Battery operated Scene controller wall or table mounted
Is GE 45631 Z-WAVE WIRELESS KEYPAD CONTROLLER
Basement application: Need some advice
Digital skylight! Help with Phillips Hue and Accessory Switch
Recommendations - Automated Lighting
No Motor garage door opener (HomeLink button integration?)
Dark Color Multi-button Wall Switch?
A15 smart light bulb? (Making a ceiling fan smart if it has a light)
Amazon IoT programmable button on sale. For programmers, sorta
RELEASE: OSRAM Lightify Smart Dimmer Switch (button controller device handler and smart app)
Jawbone UP2 still works with ST?
Status of Light Switches with SmartThings
KNOCKI - New Device Spotted... Thoughts?
Switch to control a smart plug?
How to control 2 devices with 1 switch
Wireless Switch for New Light in UK - Best Solution?
Hank One-Key Scene controller doesn't play well with Smartthings
Button Controller for Smartthings
Current Device Deals & Best Prices (link to new thread at bottom of thread)
FAQ: Philips Hue and Other Smart Bulbs - What sort of light switches to use with them? (Long FAQ)
Physical switch or button to operate ST routines in the UK
Buttons....Is there really a reliable solution
(UK) Z-Wave/ZigBee mains-powered scene controller that does not cut power to the circuit?
Remote Control?
Multi-switch to fit in single gang box?
[Release] Z-Wave.me, Popp, & Devolo Wireless wall Controller & Key Fob (EU), with button controller dimming apps and CoRE integration
Battery operated button/switch for single gang box?
Suggestion for in-wall dimmer with satellite remote
Auxiliary Wall Switches in 2020?
Managing Eaton Halo Wifi Cans With Buttons, Switches and Dimmers/Sliders?
Normal wall switch + philips hue + fibaro? (Denmark)
Smart Switch Cover to go over current switch in UK?
(2019) Does the Leviton VRCS4-M0Z work with SmartThings?
Leviton VRCS4
Pico remote without smart light dimmer switches?
Z-Wave wireless button/remote that looks like a wall switch
ISO Key Fob
Extending network to Garage/Office (UK)
Lutron dimmer/switch as solution to 3 way issues?
3 Way LED Bulbs for Smartthings
Amazon drops support for physical Dash replenishment buttons
SmartThings Button, can you not trigger a scene?
Lutron Aurora dimmer for Hue lights (Z3-1BRL)
Advice needed for step light control based on lux
Wireless Switch-New Location
FAQ: Looking at a good Wall Switch for my Hue Bulbs (2020 Short FAQ) ( also applies to other brands of smart bulbs)
FAQ: 2019 UK options for light switches with smart bulbs?
Need help with a smart light setup for my basement
How to give easy access to Grandma to control one light?
Lighting Issue - Can you Trigger Lights from a Switch (Like a Button)? (UK)
New Home Advice Sought - To many lights - too little wall space
220v US shape Wall RF switch with physical buttons?
Z wave association groups Aeotec wall mote?
2019 Update: UK Battery operated dimmer switches?
FAQ: Confused by "Regular" Hub and "ADT" SmartThings Hub. Need clarification (2019)
Alarm keyfob or button device to arm/disarm SHM?
Tradfri Color Bulb Compatibility/Limitations?
Philips Hue help needed with Hue dimmer switch/remote
Non-philips hue remote switch options?
Any cool ideas for an empty wall switch?
They're here! : new Green Energy Battery-free Wall switches for Hue Bridge (Illumra, Busch-Jaeger, etc)
Replacement for three switches in an electrical box?
Converting dumb rocker switch to smart Zigbee switch for 7$
Wall-Mounted 120V Button Controller for Smartthings?
FAQ: SmartThings-Compatible Switches that Don’t Require Neutral (US, 2019)
I need recommendation for Button
Building a Device Handler for IKEA 5 button remote?
FAQ Dimming and turning on/off multiple lights as a group (SmartThings Classic)
FAQ: Is there a Z-Wave/ZigBee "iDevices Instant Switch" style battery-operated device available?
Zwave keypad switch
Remote switch
New Z-Wave battery powered switch controls random light
ST Keyfob for alarm use
FAQ: Button for Paws?
Latest advice for virtual 3/4 way switch setup w/o hub?
Switch for controlling shutters
DIY motorized shades - help me choose solution (in US)
Need Advice: Wall Switch, Dual Functions
Home Decorators Ceiling Fan/Light Controller MR101Z - First Impressions
Alternative to Lutron Connected Bulb Remote advice needed
Little Help with understanding ZWave secondary controllers with ST
Looking for a solution to provide a momentary switch that closes a remote dry contact / relay for HVAC ventilation
Remote button recommendation
Smart Switch to control Half-Hot Outlet
Buttons buttons buttons
Devices we don't have
Any way to do 3-way switch without wiring?
Leviton VRCS4
Selecting Smart switches and remotes for new home
Hue light triggering a routine when turned on by a normal light switch?
Feature Request - NFC for Changing Modes
Emulate Hue Tap with SmartThings
Arduino Shield Suggestions?
SmartSense Presence Sensor FAILURE
Adding manual option for smart plug in?
All the officially supported devices are listed at this link:
Buttons are a popular item though, that a few of us are exploring, so hopefully more will get into the official list soon.
…CP / Terry.
The list shows the ST devices almost exclusively ZigBee while most of the non-ST devices are ZWave. Should I be building a ZigBee or ZWave grid? I only use the ST devices and have very few, if any, problems. Certainly not the incompatibility issues I read about. I don’t know if that is because of the devices and the associated grid.
Don’t forget the Aeon Minimote as well. I use one in our bedroom to control modes in the house.
While not officially a button, we are using the Smart Things Motion Sensor inside a box on a bookshelf as a touchless switch to control several things at once. The sensor is lying flat facing up. When you wave a hand over it, Things Happen.
Visitors so far consider this way cooler than the Aeon minimote, even though we have them set up to do the same thing for one button.
I’d ideally like a near range proximity sensor for a few more cases, but lacking one, I’m going to add two more motion sensors as touchless switches, one underneath an end table and one very low down to act as a touchless foot switch by the bed. :wink:
@JDRoberts What do you use the “wave hand” over for? I would be curious about that, could you post of a picture of what the motion detector in a box looks like as well?
I’m quadriparetic, in a wheelchair with limited hand function. So even using an app or a remote is a chore.
I have a lot of non networked devices in my house that have touchless switches, including a soap dispenser, faucet, trash can that lifts the lid, and a wall switch. Work very well for me.
So I wanted something similar for SmartThings. I have a Zwave deadbolt lock which is self locking, but the turn bolt on the inside of the door is hard for me to use when I want to let someone in.
So I set up the motion detector in a box on the bookcase as a touchless switch. When I wave a hand over it, the deadbolt unlocks and the entry light comes on.
So I can let someone in or out when I want, but the door doesn’t just unlock itself everytime someone walks down that hallway.
I’m going to add another one under the end table to turn on a series of lights that light the way to my bedroom, and one as a touchless foot switch to turn off the same lights when I get into bed.
The point is these aren’t actions I necessarily want to happen every time I move through that area, but only when I specifically initiate them.
They’ll also work for other people, too, which is nice. I have home health care attendants, so I don’t want to necessarily have the control app installed on everyone’s phone, if they even have a smart phone.
Here are pictures, but there’s not much to it. The box is an insulated Bento box insert no one was using. We literally just put the sensor in the box and the box on the shelf and pushed the box back far enough that it wouldn’t trigger if someone just walked by.
Wave your hand over the box and the sensor triggers, triggering the When Things Happen SmartApp.
The box idea is original. :blush: Does anyone else have such a suggestion for a non-standard button solution?
Quite a few “open/close” physical devices can be hacked to expose two contacts of the main “open/close” switch which can then be used as a “on/off”. I have a spare garage door tilt sensor whose contacts I might use in this way; but also Monoprice Z-Wave devices have such terminals (under $30?).
And there’s a new Fibraro Binary ($50-ish) with 4 such terminals, I think.
More details pending… in short, these can be wired up to any type of switch, including one that SmartThings already hacked for fun … the Staples Easy Button ™!
One button wall mount, hummmm, seems like a waste… wny not 4-10…
I think it will just depend on the use case.
In my situation, there are three instances where I like to keep switches physically separate.
  1. anything my service dog will operate. While he can be directed to the middle switch of three, it’s a lot easier for both of us if there’s just a singleton. A big dog’s nose is much wider than a person’s finger, so it’s a physical issue as well as one of understanding.
  2. anything another person will operate for me. Happens with home health aides all the time. “Flip the switch on the right. Your other right.” :wink:
  3. foot-level switches. If you can’t see it, it’s a lot easier when the switches are physically separated.
As far as aesthetics, different people will have different opinions. Some people find a coolness factor in a single button that does a bunch of things. Other people like the control panel look.
Another option: the SmartenIT 3 toggle switch can be wall mounted or used as a table top controller. I like it a lot.
+1 on the SmartenIT. I have it as well. @JDRoberts has the great FAQ linked above. The device works very well and looks great on the wall. I’ve spoken with their sales team and they are looking to get official ST support and also working on an updated model, although no firm plans or timeframes yet. I put in a few requests for us…like a controller with more buttons! :smile:
Yet another hack to consider… @davglass wrote a proof of concept smartapp that allows an iBeacon to control a SmartThings switch. (Can be a virtual switch.) requires an iOS device in the house, though.
Anyway, it’s possible to put the iBeacon inside a decorative metal box and have a two state “button.” Weird, but works for some use cases.
IBeacon “out of range” condition:
IBeacon “in range” condition:
Topic with code details for using iBeacons with ST:
Another remote!
This is a really tiny, really cheap 3 button remote. (Well, it has 4 buttons, but only 3 work.) $15, about silver dollar size.
http://ecx.images-amazon.com/images/I/81Fe83D7fZL.SY355.jpg
And this remote is officially supported. My housemate bought it to be a universal remote that could also toggle the livingroom lights, and he’s really happy with it. I use it for voice control of the a/v equipment when combined with Amazon Echo.
Official set up instructions here:
Any model Harmony remote which works with “harmony hub” will work with the SmartThings integration. You do not use the “harmony hub extender” if you have SmartThings.
The remote pictured above is now called the “harmony companion” and is the least expensive remote model that works with the Harmony hub. This button remote plus the harmony hub lists for about $149, but is frequently on sale for right around $100 in a bundle with the Harmony Hub at Amazon or Best Buy. So shop around.
For completeness, just wanted to add a link to the Amazon Echo FAQ. This has become the primary means of light control at our house. :sunglasses:
And the Google home is now officially supported as well:
Yet another option: Walmart has a prepaid touchscreen android phone with Wi-Fi capability for under $20. This can be set up with smarttiles for a very nice night stand type solution, and you never have to activate the calling plan to make it work. This photo is @Navat604 's version, although he’s using a different phone model. More discussion in the following topic:
Here’s one used as a wallmount controller:
(US and EU) And now for something with an even bigger wow! Factor, but maybe not as practical.
It is possible to put a SmartThings multisensor in a box, and because it reports three axis orientation, you can make each side of the box represent a different scene.
There’s already a smart app to do this, called mood cube, so you can build your own box around the sensor and have it work. Some people have done really beautiful implementations of this.
From a practical standpoint the problem is quickly getting to the exact side you want because if you stop to read the indicator on each side, You may pause long enough to trigger that scene.
For this reason, it’s probably most practical just to control Hue bulbs, where you can put a color.on each side and very quickly move past it to the one you do you want.
But, there’s no reason why you couldn’t make five of the six sides mean “lights on” and one mean “lights off.” Or anything else you want to do.
It wouldn’t work for me, because I can’t physically manipulate the box well enough, I would inevitably drop it and it would spin through several scenes before coming to a stop, with my luck, probably on lights out.
But it’s something to think about for some use cases. Really fun, obviously, for mood lighting. This is @pete 's version. Very elegant.
One Community member even found an Etsy store that would make a wooden cube case for the sensor with engravings of drawings sent to them on each side. Cost for the wooden cube case was about $90, but if you want to do as little as possible yourself, or you want something to match a specific decor, this is another good option.
