Location missing from the smartthings app ios or android
Hello
Since 2 weeks i can not use my phone for interacting with my devices.
The location disappeared from phone app and i can not control anything.
I checked on internet link and there everything looks good, i have location i have devices and all ok. I tried to log off log in , delete app new and old , install new app and log in , reboot hub from smartthings www. Nothing until now.
What can i do to have location with all devices back to phone. ? Pls help
I open manually the door for my car for 2 weeks :slight_smile:
Thank you
Alex
All of my phones stopped reporting their locations and my virtual presence sensors all stopped working as soon as I deleted the old app.
Thank you.
I did that also
I delete both apps and i installed only the new app.
The new app now showing only the loading image in the middle of the screen and no location available
But on SmartThings site i see location and all devices.
are you referring to geolocation?
No
Any malware blocking, vpn or pi-hole on your home network?
Hub is assigned to a room?
Last question - if you login to account.Samsung.com what region is your account assigned to in your profile?
Have you reported the issue to ST support?
And also i do not see the possibility to select location
Location in account is Romania.
What do you mean by hub assigned to a room? Where?
Everything worked perfectly for more than 1,5 years. And also in the new app. Not only in classic app.
Yes i open a ticket
change the language on your mobile device to English (US) and see if the ST app loads
Did that
Still loading and no location
I delete now app and also reinstall
Tagging @Brad_ST
Where to assign hub to a room? On st site?
If you are able to see devices in menu > devices… then click on your hub, go to three dots in the upper right of screen and choose edit. Assign it to a room
No chance
If i click on Devices it comes back to the loading page. And nothing happens
But strange is that is no more the filter location button
Am i the only one with this issue?
You will need ST support at this point.
Thank you
One more thing
The notification are still working but in app i see no devices, no scene, no nothing
Probably everything is tied to the same issue.
I changed the phone and now is working everything.
I re-synced your location. If you are still seeing issues please notify ST support.
Thank you
Life saver :grin:
