Where do I go for viewing “live logs” in the new environment? Unlike the old IDE, I don’t see a section, tab, link, etc. for Live Logging in the Developer Workspace.
Thanks,
Jose
Thanks,
Jose
Hi, @josep1972!
Are you looking for logs of Hub-Connected devices that use Edge drivers?
If you’ve installed at least one driver and it’s currently running (this means it is handling/controlling a device), you need to set up the SmartThings CLI:
Then, use the command edge:drivers:logcat. You can see the logs of certain driver or all of them, this command it’s for the last case:
smartthings edge:drivers:logcat --hub-address=x.x.x.x --all
--hub-address refers to the Hub’s IP address which you can find in the IDE or your router’s configuration.
Thank you. This is what I was looking for.
