ddc456d1-0aa7-4b4d-b581-c74c0896f517
4:07:58 PM:
debug
Parse returned Battery Siren battery is 100%
4:07:58 PM:
debug
parse(zw device: 11, command: 8003, payload: 64 )
4:07:57 PM:
debug
sending battery refresh command
4:07:55 PM:
debug
Parse returned [Battery Siren switch is off, Battery Siren alarm is off]
4:07:55 PM:
debug
parse(zw device: 11, command: 2003, payload: 00 )
4:07:55 PM:
debug
testing siren
4:07:51 PM:
debug
Setting alarm to siren.
4:07:51 PM:
debug
4:07:51 PM:
debug
4:07:49 PM:
debug
Setting alarm to both.
4:07:48 PM:
debug
Setting alarm to strobe.
4:07:46 PM:
debug
Turning Alarm Off
Hmm, no errors. Does anything work? If you set a trigger in an app, does the siren go off? if so, does the off work? Does the test do anything.
No nothing happens I am trying everything I can, I donāt know what is going on with it. It changes status on app but does nothing with siren.
Any updates on the siren?
Thanks, Brandon
Iām really at a loss at this point. I wish I could be more help. Maybe someone else here will have some ideas.
I also have this Linear Siren. Looking at the logs, it seems to send all the right commands, but the Siren doesnāt respond to the commands being sent. Using the generic ZWave Siren provides by Smartthings will make the siren sound, but it does not allow firing the strobe only and does not provide the ability to choose how long the siren sounds when it goes off.
Any further help with this siren would be awesome!
This version actually works with the built in security app. I need to stabilize and clean it up.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Linear Z-Wave Siren
* Author: Kevin Tierney
* Date: 2015-07-30
* Updates by: Artak Kalantarian
* Date: 2015-10-13
metadata {
definition (name: "Linear Z-Wave Siren", namespace: "tierneykev", author: "Kevin Tierney") {
// capability "Actuator"
capability "Alarm"
capability "Battery"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch"
command "strobe"
command "siren"
command "both"
//Supported Command Classes
//0x20-Basic ,0x25-Binary Switch ,0x70-Configuration , 0x72-Manufacturer Specific ,0x86-Version
// fingerprint inClusters: "0x20,0x25,0x70,0x72,0x86"
fingerprint deviceId:"0x1000", inClusters: "0x25,0x70,0x72,0x80,0x86"
// 0 0 0x1000 0 0 0 4 0x25 0x70 0x72 0x86
simulator {
// reply messages
reply "2001FF,2002": "command: 2002, payload: FF"
reply "200100,2002": "command: 2002, payload: 00"
reply "200121,2002": "command: 2002, payload: 21"
reply "200142,2002": "command: 2002, payload: 42"
reply "2001FF,delay 3000,200100,2002": "command: 2002, payload: 00"
tiles {
standardTile("alarm", "device.alarm", width: 2, height: 2) {
state "both", label:'alarm!', action:'alarm.siren', icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
state "siren", label:'siren!', action:'alarm.strobe', icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
state "strobe", label:'strobe!', action:'alarm.both', icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
standardTile("off", "device.alarm", inactiveLabel: false, decoration: "flat") {
state "default", label:'Off', action:"off"
standardTile("on", "device.alarm", inactiveLabel: false, decoration: "flat") {
state "default", label:'On', action:"on"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "alarm"
details(["alarm", "off", "on", "battery","refresh"])
preferences {
input "autoStopTime", "enum", title: "Disarm Time",required:true,displayDuringSetup:true, options: ["30","60","120","Infinite"],default:'30'
def updated() {
def autoStopTimeParameter = 0
if (autoStopTime == '30') {
} else if( autoStopTime == '60'){
autoStopTimeParameter = 1
} else if (autoStopTime == '120') {
autoStopTimeParameter = 2
} else if (autoStopTime == 'Infinite') {
autoStopTimeParameter = 3
log.debug "AutoStopTime - ${autoStopTimeParameter}"
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, configurationValue: [autoStopTimeParameter])
//println org.codehaus.groovy.runtime.InvokerHelper.getVersion()
def strobe() {
log.debug "Setting alarm to strobe."
state.LastAlarmtype = 2
zwave.configurationV1.configurationSet(parameterNumber: 0, size: 1, configurationValue: [2]).format()
sendEvent(name: "alarm", value: "strobe")
on()
def siren() {
log.debug "Setting alarm to siren."
state.LastAlarmtype = 1
sendEvent(name: "alarm", value: "siren")
zwave.configurationV1.configurationSet(parameterNumber: 0, size: 1, configurationValue: [1]).format()
on()
def both() {
log.debug "Setting alarm to both."
state.LastAlarmtype = 0
sendEvent(name: "alarm", value: "both")
zwave.configurationV1.configurationSet(parameterNumber: 0, size: 1, configurationValue: [0]).format()
on()
def off() {
log.debug "Ending Test"
zwave.basicV1.basicSet(value: 0x00).format(),
zwave.basicV1.basicGet().format()
def on() {
zwave.basicV1.basicSet(value: 0xff).format(),
def result = null
def cmd = zwave.parse(description)
log.debug "parse($description) - command is $cmd"
if (cmd) {
result = createEvents(cmd)
log.debug "Parse returned ${result?.descriptionText}"
return result
def createEvents(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
log.debug "createEvents with cmd value {$cmd.value}, LastAlarmtype: $state.LastAlarmtype"
def switchValue = cmd.value ? "on" : "off"
def alarmValue
if (state.LastAlarmtype == 0) {
alarmValue = "both"
else if (state.LastAlarmtype == 2) {
alarmValue = "strobe"
else if (state.LastAlarmtype == 1) {
alarmValue = "siren"
else {
alarmValue = "off"
def res1 = [
createEvent([name: "switch", value: switchValue, type: "digital", displayed: false]),
createEvent([name: "alarm", value: alarmValue, type: "digital"])
log.debug "result is: $res1"
return res1
def createEvents(physicalgraph.zwave.Command cmd) {
log.warn "UNEXPECTED COMMAND: $cmd"
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
if (!state.lastbat || (new Date().time) - state.lastbat > 53*60*60*1000) {
result << response(zwave.batteryV1.batteryGet())
result << response("delay 1200")
result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def createEvents(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "$device.displayName has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbatt = new Date().time
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def createEvents(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd)
log.debug "CONFIGURATIONREPORT"
def poll() {
if (secondsPast(state.lastbatt, 36*60*60)) {
return zwave.batteryV1.batteryGet().format()
} else {
return null
private Boolean secondsPast(timestamp, seconds) {
if (!(timestamp instanceof Number)) {
if (timestamp instanceof Date) {
timestamp = timestamp.time
} else if ((timestamp instanceof String) && timestamp.isNumber()) {
timestamp = timestamp.toLong()
} else {
return true
return (new Date().time - timestamp) > (seconds * 1000)
def refresh() {
log.debug "sending battery refresh command"
@artakka,
I tried using your version of the device type on a go control siren that was part of the http://www.homedepot.com/p/GoControl-Premium-DIY-Home-Security-Kit-Z-Wave-and-Wink-Enabled-WNK01-311KIT/205785810
which I think is a rebranded Linear WA105DBZ-1.
I am able to trigger the siren manually by going into āThingsā menu, and selecting the siren. Under which I can also switch the mode between āAlarmā, āsirenā or āstrobeā.
However, I cannot get Smart Home Monitor to trigger the siren properly. When an intrusion was triggered, instead of sounding the siren, it only sets the siren into āalarm modeā. I can see the red led flashing confirming that the command was received.
Are you able to trigger the siren properly with SHM?
thanks,
Johnny
@jakers102 Try this version
* Date: 2015-07-30
* Date: 2015-10-13
metadata {
capability "Alarm"
capability "Sensor"
capability "Switch"
command "strobe"
command "siren"
command "both"
simulator {
// reply messages
tiles {
main "alarm"
preferences {
def updated() {
def strobe() {
on()
def siren() {
on()
def both() {
on()
def off() {
def on() {
def result = null
if (cmd) {
return result
def alarmValue
alarmValue = "both"
else {
alarmValue = "off"
def res1 = [
return res1
result
map.value = 1
} else {
def poll() {
} else {
return null
} else {
return true
def refresh() {
Hi,
I just used the device type code above. When my GoControl siren from the same kit (Linear Sirenā¦it says so in the instruction sheet, and includes the command instructions at the beginning of this thread) was included in the Hub, it immediately used the device type I created with the code.
If I tap the icon on the āThingsā screen, it immediately sets off the siren and strobe. I can also toggle between alarm, siren or strobe from the āThingsā screen, but it doesnāt seem to change the siren.
If I go into the Devices screen, I can turn off/on the siren, and I can toggle between the modes, but againā¦it still just runs the siren and strobe at the same time.
Summary:
Icon: if touched, immediately sets off the siren and strobe. Toggling between mode (either in Devices screen, or Things screen) has no impact on the mode.
On/off: seems to work ok
Battery: nothing yet.
Mike
Yes, I have not fixed the type change code yet. But on / off works.
I thought maybe the actions in the state section were wrong (ie state ābothā has action 'alarm.siren", etc), but I changed them and the toggling between states stopped working, as did on/off.
I looked at the rest of the codeā¦the config change values look correct, per the Linear config instructions. Not sure why the siren wonāt change states correctly.
One additional item: I also tested it with Smart Home Monitor. Siren didnāt trigger (but SHM shows the Siren as activated).
Edit: Tested with āZ-wave Sirenā device type. āoff/onā works, as does Battery % reporting. Iāll keep checking, but for some reason the configuration values (siren, strobe or both) donāt work.
Making progressā¦I fixed a number of things:
- āActuatorā was commented out at the beginningā¦fixed that. That a key capability.
- on () command was in each of the function change def (strobe, siren, both) areas. This make the siren immediately go off each time you tried to change function. Removed the on statementsā¦now it works fine.
- def strobe had an event line in the wrong area, which prevented the strobe config function from executing correctly. Moved the line up two rowsā¦works now.
Now the following worksā¦basically everything, except SHM (the key reason to have a siren!!!)
on/off (turns it on/off as expected)
battery reporting works
changes siren modes works
disarm time works
* Linear Zwave Siren v2
* Copyright 2015 Kevin Tierney
metadata {
capability "Alarm"
capability "Sensor"
capability "Switch"
command "strobe"
command "siren"
command "both"
simulator {
// reply messages
tiles {
main "alarm"
preferences {
def updated() {
def strobe() {
def siren() {
def both() {
def off() {
log.debug "sending off"
def on() {
log.debug "sending on"
def result = null
if (cmd) {
return result
def alarmValue
alarmValue = "both"
else {
alarmValue = "off"
def res1 = [
return res1
result
map.value = 1
} else {
def poll() {
} else {
return null
} else {
return true
def refresh() {
And now I think I see why my device type commands ddināt work. I was missing the format() at the end of all my zwave commands
Updated working code. I have a support ticket open with Smartthings support on integration with Smart Home Monitor. However, I got it to work with SHM, but it seems like a workaround. SHM sends a ābothā command to turn the alarm on, when it really should be sending an āonā command. I created separate commands to config the alarm type, then setup a ādef bothā to get it to turn on. If Smartthings starts sending just an āon()ā message, it should still work ok (I think).
Anyway, here ya go:
PS: Kevin, how can I paste this code in a scrolling window? Iām sure itās obvious, but I donāt see it.
* Linear Zwave Siren v3
*Author: Kevin Tierney
* Date: 2015-07-30
* Updates by: Mike Wilson
* Date: 2015-11-01
metadata {
definition (name: "Linear Z-Wave Siren v3", namespace: "tierneykev", author: "Kevin Tierney") {
capability "Alarm"
capability "Sensor"
capability "Switch"
command "setstrobe"
command "setsiren"
command "setboth"
simulator {
// reply messages
tiles {
log.debug "Adjusting alarm state"
state "both", label:'alarm!', action:"setsiren", icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
state "siren", label:'siren!', action:"setstrobe", icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
state "strobe", label:'strobe!', action:"setboth", icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
main "alarm"
details(["alarm","off","on","battery","refresh"])
preferences {
def updated() {
def setstrobe() {
def setsiren() {
def setboth() {
def off() {
def on() {
def both() {
log.debug "sending alarm on via both"
def result = null
if (cmd) {
return result
def alarmValue
alarmValue = "both"
else {
alarmValue = "off"
result
map.value = 1
} else {
def poll() {
} else {
return null
} else {
return true
def refresh() {
Here it is with the scoller. Paste all the code in, then highlight your code and either do Ctrl-K or Click on the </>
It also works if you put your code in github and paste a link to it
* Copyright 2015 Mike Wilson
metadata {
definition (name: "Linear Z-Wave Siren v3", namespace: "miketx", author: "Mike Wilson") {
capability "Alarm"
capability "Sensor"
capability "Switch"
command "setstrobe"
command "setsiren"
command "setboth"
simulator {
// reply messages
tiles {
main "alarm"
preferences {
def updated() {
def setstrobe() {
def setsiren() {
def setboth() {
def off() {
def on() {
def both() {
def result = null
if (cmd) {
return result
def alarmValue
alarmValue = "both"
else {
alarmValue = "off"
result
map.value = 1
} else {
def poll() {
} else {
return null
} else {
return true
def refresh() {
Coolā¦thanks Kevin! I fixed my post above so it wouldnāt take up so much space!
I just updated device type. I can choose alert ( strobe, siren,alarm) and they display properly in app and api, but regardless of which is chosen both siren and strobe activate when triggered
Did you use the latest code I posted? I just did a quick test again and everything functions as it should, including with SHM. After you set the alarm type, did you try it with the on/off buttons and did that work?
My Linear siren is model ZM1601US (comes in the GoControl kitā¦battery operated model (not AC model, which is Linear WA105DBZ-1, but both support the same configuration commands and function the same, per the instruction sheet).
