The alarm works as a Zwave Switch Device template. The incluster mentioned basic, battery, configuration, manufacturer, and version.
fingerprint deviceId:“0x2001”, inClusters:"0x25, 0x80, 0x70, 0x72, 0x86"
I took the Zwave Switch Device template and am building on top of this to enable battery level notification and configuration. According to the instructions, the alarm supports parameters 0 and 1 of configuration command. Paramater 0 supports strobe/siren. Parameter 1 supports timeout.
My first goal was simply to report battery level notification. My second goal was to enable a tile and function to set configuration for both parameters. Maybe this needs two tiles but haven’t determined on the UI… I haven’t divereged too much from the original Zwave Switch template as I got stuck on the simulator. I don’t want to assign this code to my alarm because I’m at work and still need the alarm to function normally.
// Switch Binary 0x25 V1
// Battery 0x80 V1
// Configuration 0x70 V1 V2
// Manufacturer Specific 0x72 V1 V2
// Version 0x86 V1
metadata {
definition (name: "Z-Wave Switch/Alarm Test", namespace: "tutran.com", author: "Tuan Tran") {
capability "Actuator"
capability "Indicator"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Battery"
//fingerprint inClusters: "0x25"
fingerprint /*deviceId:"0x2001",*/ inClusters:"0x25, 0x80, 0x70, 0x72, 0x86"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("indicator", "device.indicatorStatus", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "when off", action:"indicator.indicatorWhenOn", icon:"st.indicators.lit-when-off"
state "when on", action:"indicator.indicatorNever", icon:"st.indicators.lit-when-on"
state "never", action:"indicator.indicatorWhenOff", icon:"st.indicators.never-lit"
standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("battery", "device.battery", width: 2, height: 2, decoration: "flat", inactiveLabel: false) {
state "battery", label:'${currentValue}% battery', unit:""
main "switch"
details(["switch","refresh","indicator","battery"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, // Basic
0x80: 1, // Battery
0x70: 1 // Configuration
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug "Was hailed: requesting state update"
} else {
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
def value = "when off"
if (cmd.configurationValue[0] == 1) {value = "when on"}
if (cmd.configurationValue[0] == 2) {value = "never"}
[name: "indicatorStatus", value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
// Handles all Z-Wave commands we aren't interested in
log.debug "Unhandled cmd:" + cmd
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def refresh() {
delayBetween([
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format(),
zwave.configurationV1.configurationReport().format() // tstdebug
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on", display: false)
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off", display: false)
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never", display: false)
zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 3, size: 1).format()
def invertSwitch(invert=true) {
if (invert) {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
else {
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
