Weird issue we got this morning - we have a set of ceiling lights that are connected to a dimmer (GE Zwave) - and this morning even when the switch is off, one light keeps switching on and off - as if it was pulsating - off and on, off and on. This goes away when I switch on the lights but comes back when they are off.
Never seen this before and the switch isn’t new, nor are the lights - any ideas?
BTW, 6 lights are controlled in the ceiling and one of the, does this; when I removed that bulb another one started doing it, and when I put it back then the original one started doing this. And I don’t believe in ghosts.
Sounds like the dimmer is letting through some current. This tends to be worse with some LED bulbs and CFLs. Have you tried a different bulb? I have a fitting that has bulbs that flash. A new LED fixed it but before that, I had to use incandescent
I was thinking I will swap with a few others and then see how it goes; again it wasn’t new so that’s the mysterious part at least to me. Of course the switch could go bad, but have anyone else seen that?
Yes actually I have, but the older 46xxx models of switches from GE. If nothing has changed with your setup, and switching out bulbs makes no difference, then you could have a switch going bad.
