Has anyone tried extending the Phillips HUE LED light strips? I have been eyeing something like these: http://www.hitlights.com/ls5050-rgb150nw44k-65ft-392.html and wonder if I could use the extensions they provide, to the Phillips solution that SmartThings integrates with.
I have a ledge right now in my house that uses 3 rope lights, that I want to replace! Color control, and automation would be incredibly awesome, and look amazing.
Don’t you have enough outlets to just run multiples? ST could control the group. But at that point you’re talking some serious money for Hue. Is the color changing worth that? Otherwise, an off the shelf LED rope that’s long enough and a z-wave switch would probably save you money.
I really don’t know, but to me this sounds like some DEEP understanding of how Hue addresses hardware would be necessary. You would likely have to reverse engineer how it addresses the LEDs and then make sure that the added LEDs were capable of understanding that.
Nothing I would ever consider but if that sounds like something you can do, more power to you!
This is beyond good news here. I have jumped into HA with both feet, in the process of a remodel and wanting security, lighting and some fun with this hobby, I have lost a lot of sleep researching the heck out of all aspects, systems, devices, etc. in two months, we’ve spent on over 20 devices. For my money, Hue is out, not versatile enough for the buck. RGB LED strips are cost efficient and there/ no end to the use, but the lack of a controller is a glaring gap in the market. I have read race reviews from owners of Fibaro’s RGB controller, but everything points to EU only and missed US promises. You imply you have one, that is incredible! Although, I cannot imagine why others haven’t paired a radio to the wired RGB controllers that exist…
I plan on installing under cabinet RGB LED strips in the kitchen as well as other accent lighting. Should I plan on using Fibaro as the RGB controller? Are there other options?
Hey everyone, has any solution been made on this as of yet? I saw a message from @Duncan saying they were working on the Fibaro, which to me would be the best solution—but haven’t received any update…
@DinnerYeti
The Fibaro appears to be a nice device with many features. I like that it includes inputs that I can use for cabinet open/close sensors. There just isn’t a good device type written for it yet. You can only use the dimmer and there is a custom device type that uses sliders to awkwardly control RGB color but not white in RGBW.
I have the second controller you pictured by docooler and would love to get it hooked up to smartthings.
I found this site http://g.chasefox.net/zentyal/unifi/rgb-led that showed how to login into the controller and some examples of a java api to talk to it. does this information help to create a device type?
