Has anyone used the LeakSmart valve with ST (Link)? Specifically I’m wanting to use the utilitech leak sensors to trigger this valve in the event of a leak. Cheers!
There are a few members using this valve and I believe it does work with ST. Here is one of the device handler but you can also do a search for “leaksmart” and there are a couple more posts about this.
Thanks for the feedback! Are you using any moisture sensors? If so, which ones? I just got in on the $6 Utilitech sensor deal at Lowes. I’m hoping to make the two work together.
I have tons of moisture sensors - not actually sure how many! In fact two more just arrived today.
I have the original ST Fortrezz (don’t buy this one)
Many PEQs - these are great
The lowes utilitech - this one is great if you need the leads (I use it in my sump pump) otherwise I don’t like it
because it is hard to tell if it is connected (the other sensors monitor temp and you can see that they updated recently) but I use a new DTH that allows it to be seen in Simple Device Viewer so I know that it is connected and monitoring.
Today I just got a delivery of the new ST moisture sensors - so no feed back on these yet.
Excellent! I’ve got 15 of the Lowe’s sensors coming because they were cheap. I’ll make sure I have them loaded in the simple device viewer as well. Thanks for the feedback.
