Labs: Netatmo Integration
@Evil_V it is doing the same thing to me and my grovestream as well.
Hey all, this is partially my fault. Netatmo disabled http access to their API today and the SSL certificate they use isn’t currently supported by ST. I’m working with people to figure out how to get this fixed.
Netatmo is not working on IFTTT either. thats a good way to cut yourself out of the market, stop making your things work with other things…what was netatmo thinking.
I also contacted Netatmo’s support, I was told they are experiencing server issues and it would be resolved soon. So maybe it’s all related.
Thanks @Dianoga!
Any idea how long this will be?
Any ETA? Parts of my home automation are dependent from my external temperature sensor and right now they don’t work…
Hi Brian,
Do you have an ETA on this by chance? We’re using the Netatmo+SmartThings integration at WeatherBug for an upcoming project (I’m an IT consultant for WeatherBug), and it is crucial that the Netatmo+SmartThings integration be working ASAP.
By the way, we’re going to be doing some more with SmartThings coming up with WeatherBug. You might be interested in developing some SmartThings apps for us. If you go to Backyard.WeatherBug.com and under “Backyard Stations”, select “Backyard Stations Help” and fill out the contact form on there, I can introduce you to our CTO and API’s.
Suggestion: Can you look into seeing if you can get the direct data feed from Netatmo? That would bypass all the SSL/sign in issues you’re having with the app for now. The only drawback with such a setup is only public stations would be visible in the feed, and even if a person didn’t own a Netatmo, they could view other people’s nearby stations inside SmartThings.
However, the majority of our users at WeatherBug that’ll be using a Netatmo with SmartThings will want to publish their data directly. We may decide to integrate Netatmo’s feed into WeatherBug.com as well since the whole SSL/sign in integration with SmartThings hasn’t been that reliable. I believe it’d be a more reliable way to pull it off.
By the way, I’ve got a suggestion for a SmartThings app you might want to build that would be up your alley…
What’s the idea? Post it here and others from the community can decide to write it as well;). Like me cough cough
Fill out this form with your name and email (ignore the other forms). In the subject line, put “SmartThings App”.
http://backyard.weatherbug.com/group/backyardstations
I would need to introduce you to our CTO and have him give you access to some of our API’s.
Here’s a quick rundown of what I’m looking for:
We’re going to be doing more with SmartThings with an upcoming WeatherBug project (http://weatherbughome.com). I’m looking for an app that can take data from both our professional and personal weather station network at WeatherBug.com and be able to access the station data inside SmartThings. That way, owners with other brand PWS’s besides Netatmo (Davis, Rainwise, Peet Bros, Ambient, Oregon Scientific, etc.) could integrate their station data inside SmartThings and use it to control SmartThings, regardless of the station brand. As long as the data is being pulled from WeatherBug.com, it would display in SmartThings. Users without a PWS could still use their nearest WeatherBug.com station (whether a PWS or a professional station installed in a school or business) inside SmartThings.
That would offer a LOT more station support inside SmartThings without the needs for various apps or station brands to manually get involved. One app/feed would do the trick.
If you’re interested, email me at the form above, and I’ll introduce you to my CTO and team.
Another SmartThings app I’m needing done is one that would allow the Nest thermostat to integrate into SmartThings. I don’t personally own a Nest thermostat, but I’m going to be recommending SmartThings to people that do own Nest thermostats coming up. By default, the Nest thermostat is not supported by SmartThings. An app that would allow the Nest to be controlled by SmartThings, as well as pull the temperature data from a Nest thermostat into SmartThings, would be handy.
This should help you out :smile:
Sounds good. So that would allow a Nest to integrate OK with SmartThings?
Yep. It’s community supported at the moment. Not official by SmartThings… Yet
OK great. That’ll at least still give our weather community members something to use to integrate their Nests into SmartThings until something more official drops. :slight_smile:
By the way, I think our own teams is going to develop the app I mentioned above, so I guess we won’t need outside help for it, but if they run into any issues, I can sure holler. :slight_smile:
Totally off topic: I am looking for a SmartThings app here (see: Hunter SimpleConnect and SmartThings), so if anyone in the developer community is adventurous enough to tackle it, I’d be happy to test it out.
anything new on this…I check it everyday and still nothing.
Any news on this?
Can we expect this to be fixed soon or will it last as the Logitech Home Control that hasn’t been working for something like 6 month?
