Unfortunately, we’re basically just a passthrough for whatever battery level the lock reports to us. But sometimes the effective battery value under load (i.e. running the motor) may be less than when it is idle. The lock may not have an accurate reading itself until after its operated once or twice. That being said: if it’s blinking red, definitely trust that over whatever is displayed in our app.
@kurtw The 1% is a value that we synthesize whenever the lock sends us a specific “low battery” message just so that it’s clear that the lock is saying its batteries should be replaced.
If you think your batteries are draining too quickly, we’ve found that locks near the edge of reliable transmission drain faster due to messages having to be re-sent. A plugged-in z-wave repeater (like a plug) between the hub and the lock may help.
