Hello, I am wondering if the kwikset 915 lockset will work with ST. I don’t see anywhere that it says works with St or nothing saying Zigbee or Z wave. o anyone have this lock and have success with being controlled by St and Alexa?
No. It has a keypad but can’t be controlled remotely.
Thanks you
I’m actually using it with the Lock Manager SmartApps from https://github.com/ethayer/lock-manager
It has a lot of features and it can be lock and unlock remotely.
Check your model number. The versions which include a Z wave or zigbee module and can therefore be integrated with SmartThings are the 916, not the 915.
You are correct. It is the 916 and not the 915. The 916 has what they call “Home Connect” for Z Wave or Zigbee.
If my home came standard built with a 915 but I buy the zwave plus module to plug into it, will I be able to use it as a smart lock then?
