Issues with SmartThings Routines and Honeywell T6 Pro Z-Wave Thermostat
I am attempting to setup a day and nighttime routine in the ST app to control the temp on my Honeywell T6 Pro Z-Wave Thermostat. While I am able to manually adjust the temp up/down, set cooling/heating mode, etc. in the ST app, the routine automations are not working (i.e. cool to 74 at 9 pm and cool to 76 at 6 am). Does anyone have any recommendations?
Please post screenshots of your Routines.
The T6 pro doesn’t automatically switch over from heating to cooling. If you’re trying to do that it may be an issue. You’ll need a custom driver to enable that feature in the thermostat.
Out of curiosity, why would you not use the thermostat’s built in programming to do that instead of relying on two different clouds?
It was my understanding that the t6 pro does provide for auto-changeover. It sounds as though it’s buried in the settings:
The Honeywell site
and a Hubitat discussion. “…Advanced settings to enable it (option 300)”
I am hoping to get some response about an EDGE driver for the T6 Pro.
I purchased one and installed it in a Hubitat environment, and it’s a very nice thermostat with good support with Hubitat.
However, I want to install two of them in a SmartThings environment, so I can remotely monitor and sync if my tenants change the settings on the thermostats. (I need to sync the Honeywells with a mini-split system that is not compatible with Z-Wave, argh).
From everything I’ve dug up, it seems that the Honeywell T6 Pro is not supported by SmartThings.
Or does someone know if there’s a generic thermostat EDGE driver that will control the T6 Pro?
I don’t think I need anything fancy, just notification if the settings arre changed, and possibly adjustment of temperature settings and mode.
Thanks for any help.
The Honeywell T6 Z-wave Thermostat is supported by the “Z-Wave Thermostat Mc” driver. I don’t know if the T6 Pro is the same or different than the T6.
What are the fingerprints for your T6 Pro?
Thanks Paul. I’ve found the GitHub list of EDGE drivers, and it lists the T6 Pro in the fingerprint list, using the device profile “base thermostat”, which looks to cover the basics anyway…
@RBoy has indicated that it’s ‘in the works’, so I’ll hope that he comes up with one that takes it as far as it will go, (with his usual sensible GUI…)
It looks like it’s worth at least trying it in SmartThings, at any rate. I’ll be able to adjust it remotely, even if I have to regularly think to check it.
Thanks again.
To follow up, I’ve found that the thermostats do work with SmartThings, but uses the generic “Zwave Thermostat” “base thermostat” driver. I haven’t gotten to know it as well as I’d like, but at this point I see that it’s lacking a few Honeywell-specific functions. Schedule edit, and enable, is one.
I’m hoping to find a driver that utilizes the specific functions of the T6.
Fingerprint info:
Manufacturer Code
0039-0011-0008
Model
0011-0008
Thanks for any help!
