I can confirm the Smartthings buttons and contact sensors work in zigbee2mqtt, https://www.zigbee2mqtt.io/ which can connect to Home-assistant or any other MQTT service. You need a zigbee stick though if you’re not going to use the Smartthings hub.
Anything new on this area. I installed Home Assistant on my Sonlology via docker. First I couldent do the integration just because my Home Assistant was using HTTP.
I struggled a bit to get the SSL/HTTPS working. But that now works fine. But now I get this “The token does not have what is required within the scope of OAuth.” when trying to save the Token. This is the first time I try to integrate SmartThings to Home Assistant so no old Smartthings settings in my configuration. I’m using version “core-2021.9.5” of Home Assistant.
Is it something I have to add/re-do regaring to SSL in configuration.yaml? Or should I just replace Smartthings with something else?
