I don’t have smartthings yet. I would much rather have smartthings than wink hub and cant find an easy solution. Thanks for the help
There is a device called Bond that is suppose to work with RF devices to integrate into smart things. There is also a zigbee fan controller from Home depot that can be integrated with smart things. The Home depot fan controller is labeled as supported by Wink, but there is a custom device handler by the community that works pretty well.
Very long thread on this topic but short answer is yes. If you have any specific questions I would recommend posting there since users of this integration will be notified:
I’m new to smartthings can you please explain what this means. I have this fan and received my smartthings hub today.
First, you should use this thread to ask questions. It has a lot of discussions and tips on your device.
When you go to that thread, answer these question: Is your hub set up yet? Do you know which ST app you are using? (Classic vs New)
