bass_rock
(Daniel )
October 1, 2016, 7:22pm
1
I recently bought this wink connected fan: http://www.homedepot.com/p/Home-Decorators-Collection-Gardinier-52-in-LED-Brushed-Nickel-Ceiling-Fan-43260/206648825
Is there any chance of it being able to be used with SmartThings or will I have to switch or get a wink HUB?
danjp
(Daniel Pena)
October 1, 2016, 7:43pm
2
Does it have zigbee or Z-wave? Does it require the Wink hub or just the wink app?
bass_rock
(Daniel )
October 1, 2016, 7:54pm
3
I do not know if it is zigbee or z-wave definitely, but from other forums it seems it may be zigbee. And it requires the hub and the app.
danjp
(Daniel Pena)
October 1, 2016, 8:10pm
4
Have you tried adding a device via the SmartThings app?
tpip
October 2, 2016, 4:55am
5
The website doesn’t say if it’s zigbee or zwave. If it is like other Wink labeled products at Home Depot, it should work with ST. It has a remote for control and requires a hub to control from a smartphone. ST hub should work in place of wink hub.
JB_Bentz
(J Bentz)
November 10, 2016, 2:46pm
6
Anyone have luck with this fan yet?
I found one at the local store this last weekend, but when I got it home and opened it, I realized that someone had taken the controller and the remote, and returned the box to the store. I’m trying to track down another one that is actually complete.
I just purchased the fan and it seems to pair with the SmartThing hub ok, but now the status is “Please Wait”.
There is a similar posting: Hampton Bay Zigbee Fan controller
Hopefully with the info I posted there someone can help figure out how to program this device into SmartThings
ranga
(Ranga Pedamallu)
March 3, 2017, 3:56pm
8
Just released a device handler, you can try it.
This topic is to discuss the Hampton Bay/Home Decorators Zigbee Ceiling Fan Controller.
Created an initial device handler. Still in Alpha state and will be posting the code after some cleanup.
Below is the description:
Endpoint 01
Profile ID 0104
Device ID 000E
Device version 00
Number of in/server clusters 07
List of In/server clusters 0000 0003 0004 0005 0006 0008 0202
Number of out/client clusters 02
List of out/client clusters 0003 0019
I am able to use the clusters 0006 & 0008 for turning the light bulb on and dimming it. And 0202 cluster to set the fan On/Off/Breeze/Low/Medium/High.
Updated Screenshot:
[image]
You can use the following for integrating the IDE:
Owner: rangasuman
Branch: Master
Select the following DTH:
devicetypes/ranga/homedecora…
