Hi all
Early days of looking at the Smartthings apps & hardware.
I wondered if there was a way I could use the SmartThings app to be able to switch on a PC that is connected to the same network as the Samsung Smart Hub by sending a Wake on LAN command?
tgauchat
2
We get basically ZERO low-level control over the networking facilities of the Hub (even Hub V2). Eventually this may improve somewhat, but I doubt it will be as open as say, a DD-WRT Router.
Wake-On-Lan packets require, ummm, UDP, or even lower level protocols.
The easiest way to implement, likely, is to use a DD-WRT compatible Routerā¦
+1 DD-WRT for WOL, or phone apps, but both are manual methods.
The easiest way I have to wake a PC automatically is an Aeon plug-in smart switch, with PC BIOS set to boot on power-restored. This is easy to include in ST routines, Alexa can use it too.
Havenāt found a way to start most laptops other than a mechanical button press.
What a pity, but yes I understand what you are saying. Given SmartThings is all about controlling your home remotely, Im surprised that ability to send a magic packet isnāt already a feature - I think all network cards these days have WOL capability & it would remove the need to have to purchase a separate switch or socket! I think every owner of a Smart Things hub could benefit from this capability.
I do have a router which supports WOL & sending a magic packet, but given the Smart Things hub v2 is sat on my network & I already have the ability to communicate with it securely from the Internet, I would prefer to do it using that than opening up my router to the internet.
I spent a little more time researching this this morning & found this specific question comes up a lot on this forum & for similar devices.
But thank you for your responses. What a great community.
Most of the solutions Iāve seen use another device to proxy the WoL command. Eg. The SmartThings hub talks to a router, Raspberry Pi, Arduino, or Android device to trigger the event.
If you have a dedicated Android device in your home, you could use SharpTools + Tasker to accomplish this. SharpTools can react to events pushed from SmartThings and then Tasker could trigger the WoL event. Iāve played with this concept before in my house, so let me know if youād like additional details. (And Iām the developer of SharpTools)
This is a feature Iāve been fighting for! It looks like the firmware work is done, though thereās still some remaining platform work. Iāll keep the pressure on it.
As a WILD guess, I bet the 2016 Samsung SmartTVās will use WOL to turn on and since there is going to be integration with SmartThings, I bet the WOL feature will come once the 2016 TVs come outā¦
Any idea how I can do wake on lan to a device? like pc with smart things or amazon echo? i have a couple of devices with staic ip that i would like to do wol with through echo
this guy is doing some type of wol but i cant read the code
$:.push File.expand_path(āā¦/libā, FILE)
require ābravtroller/versionā
Gem::Specification.new do |gem|
gem.name = 'bravtrollerā
gem.version = Bravtroller::VERSION
gem.summary = "Controller for the Bravia KDL-50W700B"
gem.description = āController for the Bravia KDL-50W700B supporting WOL and IRCC (Remote Control emulation). Likely supports other Sony devivces that expose the same servicesā
Iām SO close⦠OK, I used the device handler from this post and with a minor edit I was able to get that working to at least hibernate my PC from smartthings, but implementing the script file he posted is proving very difficult. Iām using Tomato firmware and Iām coming to the conclusion that it wonāt work⦠In the meantime Iām using a different app that will WOL my PC from anywhere and the device handler above to shutdown my PC (at least I was able to automate the shutdown when I leave my houseā¦)
If anybody has advice on how to get it working on Tomato thatād be swell.
Well, Iām one step closer⦠I found a website/service that will send the WOL packet if you enter the URL with your connection info,. https://www.depicus.com/wake-on-lan/woli?m=MAC ADDRESS HERE&i=IP OR HOSTNAME HERE&s=255.255.255.255&p=PORT HERE
If someone would be willing to modify a smart app (such as the one I posted above) to facilitate this plus a way to āpingā the PC status Iād be stoked⦠and willing to offer some compensation.
I have a Plex media server and would love to be able to put it into sleep and wake it at certain times of the day (e.g. at night) to save power. Hereās hoping a WOL capability is coming for half of the solution.
OK, we can turn the PC on and off but what about something that can ping the PC to keep the status buttons in sync?
Only way I have figured out so far is by using an Iris Power Plug to monitor Power Use. I created a piston in CoRE to keep the Virtual Switch and physical on/off in sync.
