Is there a way to see defined automatios/routines with CLI?
Hi,
If I define an automation in the app (Android, if it matters), is there a way to see the defined automation in smartthings CLI?
I tried rules command, but it returns empty.
Sorry, up to now, there’s no endpoint in the ST API that provides the routines created in the mobile app.
Also, for the Rules, take into consideration that, the results of the GET requests to https://api.smartthings.com/rules?locationId=ID will depend on the Access Token type you use.
For example, if you created a Rule using a SmartApp token, you won’t get those Rules listed using a Personal Access Token (PAT).
Are there plans to support it eventually? What is the major difference between rules and automatic routines which would be a reason to choose one over another? Maybe you plan to converge them in the future or remove one of them?
