Iris DURAFLAME Space Heater (2023)
Hi, @ramki_cmc
I found a publication from 2017 with DTH information for this device.
Maybe it can be added to the thermostat driver.
I have some doubts:
  • Did it have a switch to turn it on and off?
  • Were the operating modes Off, Heat, Auto and Eco?
  • When you press the Off switch, does the thermostat mode go to Off?
  • When you press the On switch, does the thermostat mode change to Auto?
Thanks for checking this @Mariano_Colmenarejo . I think this is the same DTH I used before. My responses below.
  • Did it have a switch to turn it on and off? - Yes
  • Were the operating modes Off, Heat, Auto and Eco? - Yes
  • When you press the Off switch, does the thermostat mode go to Off? - Yes, all lights turn off. This is a soft off button, so the electronics is powered.
  • When you press the On switch, does the thermostat mode change to Auto? - Yes.
Here is the link to the product:
https://www.lowes.com/pd/Duraflame-1500-Watt-Infrared-Cabinet-Electric-Space-Heater/1000137253
Let me know if you need anything else. Thanks.
Added to this driver TEST version in my shared channel
Try if it works.
Has a preference to select single or Multi tile, default is single
If something doesn’t work, send me logs with the CLi so I can analyze it
 Name         Zigbee Thermostat Mc-TEST
 Version      2023-11-13T22:34:41.301045832
- id: "Duraflame/20QI071ARA"
    deviceLabel: Duraflame Thermostat
    manufacturer: Twin-Star International
    model: 20QI071ARA
    deviceProfileName: thermostat-duraflame
Thanks @Mariano_Colmenarejo. I installed the TEST driver, the UI is showing and the heater is now responding. On/Off and mode change functions work. Temperature setting function does not work. Pressing + or - doesn’t made any changes and the value is blank on the left of +/-. The screen does show the current temperature.
Correction. It does work now (temperature setting). It took a while to show up, but I am able to change the temperature.
Appreciate your support.
Hi @ramki_cmc
I’m glad it works.
Does ECO mode work?
I think the intantaneusDemand attribute for the power reports was configured incorrectly.
It is fixed in this version, but you would have to pair it or make a driver change and return to this driver so that it is configured
 Version      2023-11-14T11:49:56.624580852
Can I merge to the definitive version of Mc driver?
Hi @Mariano_Colmenarejo : Yes, ECO mode works. Alexa wasn’t detecting the thermostat properly, but I had to remove it and had it rediscover it (it previously detected as a switch). I will repair and let you know later today for the power reports. But I do see power bar charges in the UI.
Hi @ramki_cmc
You don’t need to uninstall, you can switch to this final Mc driver version and the instantaneusDemand attribute will be configured
 Version      2023-11-14T17:38:12.81200515
The final driver isn’t working. No matching fingerprints.
Error changing device driver to β€œZ-Wave Thermostat Mc”. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.
Delete old version from your hub and install the new version from my channel
@Mariano_Colmenarejo: I tried uninstalling and reinstallation Z-Wave Thermostat Mc. Still giving same error. I used your page to uninstall/reinstall. Is that the right process?
The correct name is Zigbee Thermostat Mc instead Zwave
I published a new verion
 Version      2023-11-14T18:17:48.157875887
Sorry, my mistake. I was wondering why the new driver wasn’t next the TEST one :slight_smile: .
I installed the Zigbee one and tested the functions. Works well. Thank you very much.
