iOS app unable to see devices
Hi @MRTAKATM
Could you please share a recording demonstrating the issue?
Could you provide support access to your account, please?
  1. Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM.
Also, to analyze the problem, it is important to get the logs. You could help us to reproduce the error and, once you find it, send us the logs.
After replicating, please share the app logs as well.
First:
  1. Enable the creation of additional logs in the app:
  1. In the ST app, go to “menu” > “settings”.
  2. At the bottom of that page, you’ll find a section called “Troubleshooting”. Please, enable the option that says “Create Additional SmartThings Log”.
  3. Restart the app
    Then:
  1. In the app menu, go to “contact us”
  2. Then, tap on “Error reports”
  3. On the opened page, tap 10 times on the title/label “What is the error about?” or until the prompt to create a log appears.
  4. Click on “ok” and wait for the process to finish. Then, save the generated file in the place you prefer and share it with us at build@smartthings.com
Thanks Itati, shared and emailed as requested.
same behavior here.
android works fine. tried on my iphone’s work phone and have the same issue - signed in to the same Samsung account and cannot see the devices.
when there will be a fix for that?
so… something to try.
If Developer mode is enabled - disable it.
if Developer mode is not enabled - enable it, restart your phone, then disable Developer Mode, restart phone.
  • Launch the SmartThings app.
  • Tap the Menu tab on the bottom navigation bar.
  • Tap the Settings gear icon. The SmartThings settings menu will appear.
  • Long-press About SmartThings for 5 seconds. A developer mode toggle will appear in the settings menu.
  • Enable Developer Mode.
  • Restart the SmartThings app.
Thanks Jkp, sadly I’ve tried going into developer mode as suggested on two iPhones (XR and 16 Pro Max) and an iPad (Air 4) and none of these offer developer mode :frowning: Holding the About SmartThings seems to toggle but no additional menu appears. Looking online this seems to have been a recurring issue with the Samsung app on Apple devices.
On my iOS devices…
  • when I press the About SmartThings field, it is highlighted and at 5 seconds the highlight on the field disappears
  • Then scroll to the bottom of the screen to see the option to enable developer mode
Anyway, it was worth a shot. I saw where some pixel users where unable to see devices and disabling developer mode resolved it.
Hope you get a solution.
Hi,
I am experiencing exactly the same issue on my iOS devices.
My wife can’t see any devices on her account when she uses her iPhone 15, however it works fine on her work Android phone.
I can see my devices when I log into the cloud portal.
I have logged this with SmartThings Customer Service and it is currently with the developers to investigate. The fact that other users are experiencing the same issue, I hope they realise that there is an issue with the iOS app and they fix it asap.
Thanks Jonny, whilst I’m sorry you’re having the problem as well it proves that there’s something here that isn’t specific to our particular set ups. Like you Android devices are fine but all my iOS devices can’t see any devices on the network. Again everything is fine in the portal. Oh and interestingly old iOS 12 devices with an old version of the Smartthings app can see everything perfectly on the same network connecting to the same Smartthings system. It makes me think something has changed to do with network access in later versions of iOS but not something everyone with iOS devices experience. Hopefully the developers can find it!
Yes I agree. I’ve just tested it with an old iPad Mini with an old version of SmartThings that I haven’t updated for over a year, and like you’ve experienced I can see and operate all of my devices.
This is really frustrating as I have invested so much into my SmartThings setup and I need the app to control my Samsung Family Hub smart fridge and my Samsung robotic vacuum!
Hopefully the developers get to the bottom of it. I only started experiencing the issues after logging out of the app and logging back in! Deleting the app and doing a hard reset doesn’t work.
I have a brand new iPad that I’m about to setup as a new device, so it will be interesting to see if I can see my devices in a brand new install of the SmartThings app.
Hi JonnyT, I thought you might like to know that the Smartthings app on my iPhone and iPad has started working again. The version on both devices is 1.7.29.16.
Yes, I received a response from the developers earlier this week advising that they had identified the issue from my logs and they were working on a fix.
Glad everything is back working again! :grin:
That”s brilliant Jonny, glad you got a response from the devs, for some reason I didn’t after initial contact but nonetheless fabulous that they’ve appeared to have found the issue.
