I use a little broadlink mini to switch off and on my tv, is there a way i can get this into ST so that when i trigger my night routine, and away routine, can have my tv switch off, along with whatever else i have within these routines?
You can try. The Broadlink RM has a custom integration found on GitHub.
I use Webcore to fire a web request to RM Plugin’s HTTP Bridge. Works very well. I have used the Broadlink Smart App. It’s a bit cumbersome to set up, but does the job.
Thanks guys. Just ended up sending it back and got another harmony hub ultimate for the living room ( have another one in my Cinema Room so I’m used to using one of them )
