If we can access to the Vectorās REST API (reverse engineering), I would like to make a device handler to control it through ST.
I need to sniff HTTPS traffic between my phone and Vector. Iām trying to sniff using MITM , Charles Proxy.
I just have issues with SSL certificates.
edit2:
I think I found a way to post commands to Anki Vector from ST. (without ever using any 3rd party like a Raspberry PI)
However I need to learn how to post (hubaction) to an IP with a certificate.
Any clues on that ?
edit:
for example, the following curl command is successful for sending a command to Vector with no certificate use. How can I use hubaction command same way ?
did anyone make any progress on this? not sure quite what it would be used for since the voice part of things is already answered by the fact it has alexa onboard now. but i guess it could be useful for him to start dancing or something if someone is at the door?
