Insteon X10 Control
Hi
I had pshotton’s device type installed and working to control my old x10 devices which are connected to my Insteon Hub, but after the Smartthings Hub v2 firmware update last Thursday, the integration/devices stopped working. I can only assume that there was some kind of change in the firmware that does not work with pshotton’s original coding.
Linked to pshottons device: Insteon X10 device control
I am not familiar with coding for Smartthings…so would someone on here be able to check out the original code and make the required modifications to make it work again?
Thank you
antsmarching
