I installed the GE Z-Wave 3-Speed Wireless Rocker Fan Controls to control my Ceiling Fan. I set it up with Google Home but I can only turn it on/off via Google Home and cannot voice speed setting (low-medium-high).
Is there a special trick to this?
FYI, I can control the speed via the GE rocker switch.
The device is setup as a dimmer style so any command treating it such will work. The three speeds are set as thresholds in the level so just give a command that is in the threshold range will work
For example "Hey Google,
turn on Fan 20% = Low Speed
turn on Fan 70% = Med Speed
turn on Fan 90% = High Speed
