Hi @Itati,
Your team updated the implementation as follows:
The team says that the issue was that the endpointApp didn’t specify the schemaType.
It needed to have "schemaType": "st-schema" configured. The team has updated this and it should now work.
I tested it and confirmed that it is now working successfully.
Previously, no values were being returned in the logs, but after your team’s fix, the integrationDeleted event is being called correctly.
Thank you very much for your support.
Here are the related logs for reference:
[2025.09.03 10:26:22] [./server.js ] 🔍 Request Debug: POST /sst/schema
[2025.09.03 10:26:22] [./server.js ] 🔍 Original URL: /sst/schema
[2025.09.03 10:26:22] [./server.js ] 🔍 Base URL:
[2025.09.03 10:26:22] [./server.js ] 🔍 Path: /sst/schema
[2025.09.03 10:26:22] [./server.js ] 🔍 Headers: {"host":"oauth0623.aaa.app","user-agent":"SmartThings Integration","content-length":"825","accept":"*/*","accept-encoding":"gzip, br","cdn-loop":"cloudflare; loops=1","cf-connecting-ip":"2406:da14:f66:ae0e:918a:1c85:6b2f:c37f","cf-ipcountry":"JP","cf-ray":"979175637e77e366-NRT","cf-visitor":"{\"scheme\":\"https\"}","cf-warp-tag-id":"ed9bde21-88a8-4301-bd73-12b5ed3564e0","connection":"keep-alive","content-type":"application/json","x-forwarded-for":"2406:da14:f66:ae0e:918a:1c85:6b2f:c37f","x-forwarded-proto":"https"}
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.body:
"headers": {
"schema": "st-schema",
"version": "1.0",
"interactionType": "integrationDeleted",
"requestId": "676dd718-9b2b-4fb3-a448-aa999751d5d2"
"authentication": {
"tokenType": "Bearer",
"token": "7gO9kVtijrM6DBKJjbOAppdF"
"callbackAuthentication": {
"accessToken": "eyJhbGciOiJIUzM4NCJ9.ZWQwNDQ3MGMtN2ZhZi00OTQ1LWExYzUtNjk4NDIwNWJhOWNiOlJvUm8tMjAyNTpjNzNmNmZjMy00YmE4LTQ5YzktODIyZi0wMGMxYmYyMWVmMjY6dmlwZXJfNjBiYWIzMzAtNzI2Zi0xMWYwLTgxNzQtMTdmZjFjOTBjYzBiOmFwLW5vcnRoZWFzdC0x.iLbaR_HNL52sfIg_KqkoblLpdCHY7WAIbW3s8BCSB6PUn6KdisQbkeZ7HVAyTq33",
"refreshToken": "eyJhbGciOiJIUzM4NCJ9.Yzc1ZjVkY2MtNTEwNS00OGVlLTg1MWQtOTdjZjUxYjBkN2NmOlJvUm8tMjAyNTpjNzNmNmZjMy00YmE4LTQ5YzktODIyZi0wMGMxYmYyMWVmMjY6dmlwZXJfNjBiYWIzMzAtNzI2Zi0xMWYwLTgxNzQtMTdmZjFjOTBjYzBiOmFwLW5vcnRoZWFzdC0x.z0ws0qf0qpg6sWSlFkd0XuDZy2YIXGP6GLzDRIDKoGqp_wUtGkYyC8RWj81jhrD2"
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.headers:
"host": "oauth0623.aaa.app",
"user-agent": "SmartThings Integration",
"content-length": "825",
"accept": "*/*",
"accept-encoding": "gzip, br",
"cdn-loop": "cloudflare; loops=1",
"cf-connecting-ip": "2406:da14:f66:ae0e:918a:1c85:6b2f:c37f",
"cf-ipcountry": "JP",
"cf-ray": "979175637e77e366-NRT",
"cf-visitor": "{\"scheme\":\"https\"}",
"cf-warp-tag-id": "ed9bde21-88a8-4301-bd73-12b5ed3564e0",
"connection": "keep-alive",
"content-type": "application/json",
"x-forwarded-for": "2406:da14:f66:ae0e:918a:1c85:6b2f:c37f",
"x-forwarded-proto": "https"
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.method: POST
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.url: /
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.rawBody: {"headers":{"schema":"st-schema","version":"1.0","interactionType":"integrationDeleted","requestId":"676dd718-9b2b-4fb3-a448-aa999751d5d2"},"authentication":{"tokenType":"Bearer","token":"7gO9kVtijrM6DBKJjbOAppdF"},"callbackAuthentication":{"accessToken":"eyJhbGciOiJIUzM4NCJ9.ZWQwNDQ3MGMtN2ZhZi00OTQ1LWExYzUtNjk4NDIwNWJhOWNiOlJvUm8tMjAyNTpjNzNmNmZjMy00YmE4LTQ5YzktODIyZi0wMGMxYmYyMWVmMjY6dmlwZXJfNjBiYWIzMzAtNzI2Zi0xMWYwLTgxNzQtMTdmZjFjOTBjYzBiOmFwLW5vcnRoZWFzdC0x.iLbaR_HNL52sfIg_KqkoblLpdCHY7WAIbW3s8BCSB6PUn6KdisQbkeZ7HVAyTq33","refreshToken":"eyJhbGciOiJIUzM4NCJ9.Yzc1ZjVkY2MtNTEwNS00OGVlLTg1MWQtOTdjZjUxYjBkN2NmOlJvUm8tMjAyNTpjNzNmNmZjMy00YmE4LTQ5YzktODIyZi0wMGMxYmYyMWVmMjY6dmlwZXJfNjBiYWIzMzAtNzI2Zi0xMWYwLTgxNzQtMTdmZjFjOTBjYzBiOmFwLW5vcnRoZWFzdC0x.z0ws0qf0qpg6sWSlFkd0XuDZy2YIXGP6GLzDRIDKoGqp_wUtGkYyC8RWj81jhrD2"}}
[2025.09.03 10:26:22] [./routes/schema.js ] [/] req.body length: 825
[2025.09.03 10:26:22] [./routes/schema.js ] [/] === SMARTTHINGS REQUEST ANALYSIS ===
[2025.09.03 10:26:22] [./routes/schema.js ] [/] === END ANALYSIS ===
[2025.09.03 10:26:22] [./lib/connector.js ] [integrationDeletedHandler] start....
[2025.09.03 10:26:22] [./lib/connector.js ] [integrationDeletedHandler] accessToken: 7gO9kVtijrM6DBKJjbOAppdF
[2025.09.03 10:26:22] [./lib/db.js ] [removeToken] accessToken: 7gO9kVtijrM6DBKJjbOAppdF
[2025.09.03 10:26:22] [./lib/connector.js ] [integrationDeletedHandler] finish....
[2025.09.03 10:26:22] [./routes/schema.js ] [/] Response status: 200
[2025.09.03 10:26:22] [./routes/schema.js ] [/] Response headers: {"x-powered-by":"Express","content-type":"application/json; charset=utf-8","content-length":"140","etag":"W/\"8c-zzD+QSH8R1IaEoxcKSlX252slK8\"","set-cookie":["connect.sid=s%3ALX_tE-DyuAYluCjgDUZwuGyAQmCTivCh.KyGIrJpkvwcJerv3vCZkF1bPSNv1p%2B%2Fwllkajm088Ss; Path=/; HttpOnly"]}
[2025.09.03 10:26:22] [./server.js ] 🔍 Headers: {"host":"oauth0623.omniconnect.app","user-agent":"SmartThings Integration","content-length":"825","accept":"*/*","accept-encoding":"gzip, br","cdn-loop":"cloudflare; loops=1","cf-connecting-ip":"2406:da14:f66:ae0c:d5dc:4a5e:d22e:59b7","cf-ipcountry":"JP","cf-ray":"97917563ed77734e-NRT","cf-visitor":"{\"scheme\":\"https\"}","cf-warp-tag-id":"ed9bde21-88a8-4301-bd73-12b5ed3564e0","connection":"keep-alive","content-type":"application/json","x-forwarded-for":"2406:da14:f66:ae0c:d5dc:4a5e:d22e:59b7","x-forwarded-proto":"https"}
"headers": {
"version": "1.0",
"authentication": {
"accept": "*/*",
"cf-connecting-ip": "2406:da14:f66:ae0c:d5dc:4a5e:d22e:59b7",
"cf-ray": "97917563ed77734e-NRT",
"x-forwarded-for": "2406:da14:f66:ae0c:d5dc:4a5e:d22e:59b7",
[2025.09.03 10:26:22] [./routes/schema.js ] [/] Response status: 500
[2025.09.03 10:26:22] [./routes/schema.js ] [/] Response headers: {"x-powered-by":"Express","content-type":"application/json; charset=utf-8","content-length":"2","etag":"W/\"2-vyGp6PvFo4RvsFtPoIWeCReyIC8\"","set-cookie":["connect.sid=s%3ACIsyYjgWPtysJyA8BFYh8fdW2p7t_AtL.%2BVHrx0MkgUjPaudaOys%2BzYSbxtEQ6sgc6wKc9MUw9QM; Path=/; HttpOnly"]}
