Unlink smartthings from my app
I wonder if I could unlink smartthings account from my app according to the course below. If it is able to unlink, which url is suitable? thanks all.
SmartThings Developers | Documentation
Tagging @nayelyz
Hi, there!
The “Integration Deleted” interaction is called from the SmartThings side when:
  • We select the device created by our ST Schema Connector and delete it.
  • In the ST app, we go to Menu > Settings > Linked Services and delete the integration.
The third-party cloud can also call it by sending a stateCallback to the Schema connector (see the configuration sample for the stateCallback here):
  • The URL will depend on the endpoint you configured in your Connector’s server to receive the request from the Third-Party, in the example, the endpoint to receive the “stateCallback” and update the device state is /command
  • The difference with a common stateCallback is that to trigger the “integrationDeleted” interaction, you need to send a globalError so, the payload from the stateCallback would look like this:
  "headers": {
    "schema": "st-schema",
    "version": "1.0",
    "interactionType": "stateCallback",
    "requestId": "xxx-xxxx-xxx"
  "authentication": {
    "tokenType": "Bearer",
    "token": "token-received from SmartThings for callbacks"
  "deviceState":null,  //or "deviceState":[],
  "globalError": {
     "errorEnum": "INTEGRATION-DELETED",
     "detail": "The integration was deleted from the cloud"
Thanks to this interaction type, we can remove any saved configuration, tokens, etc. from the server.
Here’s an example using the ST Schema SDK:
I will have a try.
You help a lot! Thanks nayelyz!
@nayelyz
I have tried this method to delete integration and it works.
But response is globalError:bad request, Is that correct?
Yes, you receive an error in the updateRequest because we included the globalError in the stateCallback.
You will only receive a success message if there is no error in the stateCallback’s payload and it updates the device state correctly.
i try this way to delete the integration today again, but receive response {“globalError”:{“errorEnum”:“BAD-REQUEST”,“detail”:“deviceState missing or malformed”}} and fail. My serivce is still at linked status, observe from smartthings app.
Is that any changes i should know?
thanks!
Sorry, the JSON payload above wasn’t complete. The error is thrown because the deviceState is missing. It must always be included in the StateCallback, it can have a null or empty array([]) value.
In my sample, you can see how the this field is included in the request:
So, the payload should look like this:
