IKEA Styrbar (E2002) - Replicate IKEA Actions
Hi, I have just bought an IKEA Styrbar button and Tradfri Color bulb. Got them both into SmartThings using Yakov’s SmartThings Edge Drivers.
However, I’d like to replicate the default IKEA commands from the buttons to the bulb but struggling. The defaults are:
  • Top Button, Single Push - Turns bulb on → WORKS!
  • Top Button, Held - Increases dim → Can only select a value via ST app, whereas default allows you to stop pressing the button when you get to the desired level of dim
  • Bottom Button, Single Push - Turns bulb off → WORKS!
  • Bottom Button, Held - Decreases dim → Can only select a value via ST app, whereas default allows you to stop pressing the button when you get to the desired level of dim
  • Left Button, Single Push - Can only select a single colour, whereas default allows you to cycle through colours
  • Right Button, Single Push - Can only select a single colour, whereas default allows you to cycle through colours
Anyone managed to get this working?
Thanks.
