Ikea starkvind
@Mark_in_the_house Hi, when I add my starkvind and set the driver, it says: “This device hasn’t updated all of its status information yet.” I waited a two days and it didn’t change, then I tried removing and adding the device again but still the same thing. Do you know what the problem might be?
I made some updates yesterday. Hope it works for you. For me it works (on, off, auto, 1. speed, 3.speed and 5.speed).
never worked for me ? did you ever fix this
@Mark_in_the_house for me its still not working.
Cant choose your driver. It says:
“Error changing device driver to “STARKVIND”. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.”
Any Idea how to fix this?
Did you try removing the device and searching it again? That worked for me.
Yes of course… i did several times… thx
its working now, thank you :smiley:
How did you get it to work? For me its still not working…
I didnt do anything, it just worked when I opened the app
@Mark_in_the_house I also have a starkvind that I want to link to your Edge driver. But unfortunately, smartthings only sees the device as a thing. Any help is appreciated!
Have you loaded this driver to your ST hub
https://bestow-regional.api.smartthings.com/invite/qyMZ1b1ZeWjm
Yes I did. And enrolled the STARKVIND and starkvind-test drivers. Removed the device and reconnected. But it is nog recognized as STARKVIND.
same here…
Same here ! Also tried to go under driver and switch to another one but it says no result found. Is there a way to make sure your driver are uploaded in the Aeotec hub ?
Find the Hub icon in the mobile app, open the tile, click on 3 dots in upper right corner, chose driver and scroll down to see your installed drivers and then the installed channels.
Wonderful thanks for that tip. I see the newly installed strarkvind driver. Too bad I seem unable to use them.
How can you get that device info page? I only sees that. And under information I don’t see much
Something is obviously wrong. Try looking for the information at Samsung account and post the mfg and model.
Thanks for the Samsung account link. I never visited that page, I’m new to this. Wow tons of info. Not sure what you mean by mfg and model that I needed to find there. I have an Aeotec v3 us. Firmware 000.051.00002
Or you meant the mfg and model of my air purifier device
