I’m curious if there is anything in the works to allow mode changes in IFTTT? It would be nice if I could program my up24 to change modes when I wake up!
You could do it in a 'round about way… create a virtual on/off tile. Then write a SmartApp that watches this tile. When it turns on the app changes mode, and then turns off the tile.
Now just tie the IFTTT function to this tile.
@chrisb thanks for the solution. This sounds like more than I want to dive into right now
FWIW, I did this to try to fix the ios mobile presence issues, and it has been helping. My wife’s phone used to lose presence state about 75% of days - now that still happens, but about 50% of the time the IFTTT “virtual presence” saves it.
I’m hopeful their “ios7 only” future version of the ios app fixes it for good…
@Steve28 would you mind posting your code for this?
@JeremyWhittaker - no problem. Here’s what I did
Add an “On/Off Button Tile” device. This is will be the Switch that IFTTT toggles and the switch the app I wrote subscribes to.
Add the SmartThings Channel to IFTTT
Install the IFTTT app on your phone and create a geofence event rule that toggles the ON/Off button tile from step 1 to “on”
Make a smart app like the one below. It subscribes to the “on” events from the On/Off Button Tile in step 1. When that tile goes “on”, it switches the mode from Away to Home.
Here’s the App:
* IFTTT Presence Band-Aid
* Author: Steve Sell
* Date: 2014-01-24
preferences {
section("Select Switch to monitor"){
input "theSwitch", "capability.switch"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated(settings) {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def onHandler(evt) {
log.debug "Received on from ${theSwitch}"
if(location.mode != "Home") {
setLocationMode("Home")
} else {
log.debug "Already Home - ignoring"
theSwitch.off()
sendSms(##########,"IFTTT Arrived")
def offHandler(evt) {
log.debug "Received off from ${theSwitch}"
def initialize() {
subscribe(theSwitch, "switch.On", onHandler)
subscribe(theSwitch, "switch.Off", offHandler)
@steve28 I got this all setup but I do not see a location awareness based IFTTT app that I’m using…
Are you using IOS Location for this? I have an Android.
I have the IFTTT iOS app… maybe the android IFTTT app doesn’t have it yet? You have to activate the Location channel on the IFTTT website as well.
@stevesell Thanks for this idea, I starting doing this before I looked at your code thinking I could write to a “simulated presence sensor” from a “simulated switch.” I then quickly realized there are no commands available for a presenceSensor. What a shame this doesn’t work as advertised.
