Ideas? Multiple switches same plate
Hmmm… I’m at a lost and I know there has to be people out there that have figured this out.
I’ve bought a bunch of GE on / off switches to install through my house. I’ve read all the forums about how to install (need neutral, etc). What I never thought of being an issue is the fact that the unit itself is so wide you can’t get them close enough to one another to fit a normal wall plate (they are about 1/4" off).
I can’t be the only one out there that’s wanted to install two z-wave switches on the same plate.
HELP!!! :slight_smile:
@craig,
Are you talking about the switches themselves (ie, the white plastic part) or the metal guard that goes around?
I’ve always been able to get my switches to fit. I have plaster walls in my house. Sometimes the plaster “spilled over” in the outlet/switch area a little bit which was never a problem with the old switches, but the Zwave stuff is wider/deeper of course so I’ve needed to “chisel” out this extra plaster sometimes to make sure it fit. But they’ve always fit inside the box in the wall.
Now, that metal guard is another story. Those are designed as if they were only going into a single box. If you’re putting multiple together in a double or triple box you need to break off the metal over hang on the sides that are next to each other.
For example:
If this switch was going on the left of a double box, you’d need to break off those three tabs on the right of the switch. They’re scored so just grab 'em with a pliers and bend back and forth a few times to snap them off.
Likewise, if this switch was going on the right of a double box, you’d break off the tabs on the left. If it was going in the center of a triple box, break off the tabs on both sides.
I’ve seen some switches with a full length line (rather than tabs) that needed to be snapped off. Again, though, it was scored to make it relatively easy.
@chrisb describes it exactly right. I have a couple two switch configurations and one three switch configuration. With the metal tabs off, the switches sit completely touching and have no problem fitting into a standard switch plate, at least from a width perspective. From a depth perspective it is a completely different story. The three switch one was nearly impossible to wire without pinching a wire. If any of my Jasco switches fail, I am going to try out the Leviton ones. I don’t like the style of the switch but I hear they are much shallower than the Jasco switches.
THANK YOU everyone!!! About 15 minutes after I posted this I found this in the directions (who reads those??)
I’ve started installing, much easier / faster that that I figured that out and I’ve figured out the wiring configuration for the 3-ways in my house.
Thanks everyone for the quick responses.
