Hello. I’m relatively new to SmartThings, but I have a reasonably sized Hue collection. After some initial testing went well, I picked up a bunch of motion sensor and set about automating my lighting.
However, I’ve run into trouble with integration using the Smart Lighting SmartApp being extremely unreliable. Two examples:
I have two lights in a bedroom I want to turn off at a specific time. Pretty simple. This used to work fine, but recently I’d say it fails to work more than it’s successful. Yesterday I set four off events in 5 minute intervals to make sure they turned off and after that somehow one managed to still remain on!
In another bedroom I have four lights that turn on and off by motion sensor. Sometimes a light or two from the set fails to turn on or off. Or sometimes one has a low brightness and the others are at 100%. Or a combination of the two failures.
This was all working perfectly but now it’s borderline unusable. Any ideas what happened or what I can do to fix the issue? Both the ST Hub and Hue Bridge seem to be on the latest firmware.
