ZLL is supposed to fall back to ZHA when connected to a certified ZHA coordinator, which the SmartThings hub is.
That doesn’t always mean things will work smoothly, though.
There is a community created device type handler for the Phillips hue motion sensor, and it’s working well for some people, but other people are finding that the when used in this way, the hue motion sensor keeps falling off of the network every few days. ![]()
So it’s not guaranteed to work with smart things, and it’s not officially supported by either Hue or SmartThings when used in this manner, but you can give it a try if you want.
Another option is just to use it as a parallel means of control. You join the Hue motion sensor to the hue bridge like normal. You set it up to turn on your Hue lights through that bridge. Smartthings gets the hue bridge heartbeat about every five seconds, so it will know shortly when a Hue light came on. And you could use that light coming on to trigger other smart things events if you want, but with that potential delay.
We have this set up at my house with HomeKit. What happens when you go into a room is that the table lamps come on first (hue bulbs) and then the overhead lights come on a few seconds later. It works fine for us, but I know there are other people who wouldn’t like the zone separation effect.
So really, just depends on exactly how you want to use it. And whether you want to try the beta device type handler or not.
