Yeah it costs 50€ delivered for that module. I do have a raspberry pi too. Not so sure its worth it for a single bulb.
mozilla-iot/wiki
Developer Wiki. Contribute to mozilla-iot/wiki development by creating an account on GitHub.
Are you in the U.K.?
If so, there is another device available there that may work. It cost much less than the German device, usually around £15. It’s from an older Phillips line that was discontinued around 2008, but you can still sometimes find them on eBay in the UK. See the following thread:
Im in Ireland, that device isn’t availible on ebay anymore.
The hue dimmer switch also works great for me to reset hue bulbs. Hold the on and off button for 15 seconds with the switch very close to the bulb.
Does this factory reset the bulb or does this just unpair it to the actual dimmer switch?
I assume it’s a full reset. The light blinked three times and I was able to pair directly to a hub (Hubitat - sorry Smartthings) instead of the hue bridge it had been on.
Interesting. I think I’ll try this. I have both the Lutron and several Hue Dimmers but I’m always trying to cover my bases
V[quote=“Random, post:46, topic:84967, full:true”]
[/quote]
It resets them, but unless something has changed recently, it only works if they are on a ZLL channel. That’s the same issue with the method described in this thread. If your smartthings hub is using a non-ZLL channel, like 14, then the device issuing the reset command also has to transmit on that channel or the bulb won’t receive the reset instructions.
I actually returned my smartthings hub. I was getting sick of the downtimes of the cloud service and that the hub wont work standalone. I since then got a Hue Bridge which was able to reset a bulb that was connected directly to a smartthings hub on channel 19. At first it didnt show up but when I entered the serial number of the bulb into the app it was able to find it and pair to it.
Thanks to your posts, I was careful in avoiding that channel, and set up my channels to reduce interference as much as possible. I just wanted to point out there was an option to the Lutron switch since it’s no longer available. I thought I had also used an aeon remote to reset a hue bulb before but could be hallucinating.
I also understand the difference between a hub and bridge, so your efforts to enlighten people are working.
You have no idea how much you have helped me over the years!
Your frustrations are shared which is why I’m starting to dabble with the Hubitat hub. Plus, my internet connection is horrible so something local is my only viable solution.
Totally agree with this . @JDRoberts has made a huge difference! He’s the Prince of Smartthings. ![]()
I havent heard of this before until now. @JDRoberts, is running 100% local the kind of things ST can upgrade to with Firmware or is this an architectural/hardware impossibility? I rather like this idea since my LAN rarely goes out but my internet goes out from time to time.
I’ve only had it for a few days and am just toying with it. But I confess to standing there just turning on and off switches smiling as they work every time. There is a thread on it already if you are curious.
Thanks for the shout. There are lots of people who are super helpful in the forums, I just stand out because I’m interested in the protocols, which most people could care less about. ![]()
As far as local processing, I agree, we should take that conversation elsewhere. There is an existing thread about local processing and smart things which would be a good place for the architecture question.
Continuing the discussion from What's the deal with Nest?: Correct. I was answering this question below in the global sense. i.e., There will always be the possibility of various benefits available to Official Device Handlers and SmartApps that are not available to un-certified Community Developed ones. At the moment, the local processing benefit is inapplicable to Nest in either case. I’m not sure ST has guaranteed that community developed SmartApps/Device Types will be included in local processing right after certification. Yes, it may be included down the road, and this is not yet clear on how or what the process is to enable community developed stuffs to run locally.
As for hubitat, one of the most interesting ideas is that several people are planning to use it as an add on to smartthings, just to give them a place to do local processing for some specific use cases. So I would take those conversations to that thread:
https://community.smartthings.com/t/hubitat-elevation-hub-home-automation-that-is-local/117107
I have 3 bulbs that I want to remove from ST and link to the hue bridge |I have just purchased.
I am trying to follow these instructions but I am having problems getting the CLIP page to work.
Both Chrome and Edge complain about the certificate being invalid but I ignore this and the page is correctly shown. However when I enter “api/newdeveloper” in the URL textbox and click GET but I don’t get any response. If I hit F12 and look at the Network tab I don’t see any events when I click the GET button.
Can anyone verify whether the CLIP page on the hue bridge still works?
If you have either a Philips hue dimmer switch or an echo plus or echo show 2nd generation (the one with a zigbee radio), then you can force reset the bulbs pretty easily without using the software method above.
For Hue dimmer switch:
For echo device:
https://www.amazonforum.com/forums/devices/echo-alexa/492837-reset-philips-hue-bulb
Ah okay. I don’t have either of these but I may pick up a dimmer just fir this purpose!
Many thanks
The clip debug still works (I used it yesterday from chrome). Is your firmware up to date? Are you seeing errors in the devtools console?
A recent Bridge firmware update seems to have broken the CLIP API for many users. I didn’t try Chrome but can’t get it to display properly in Safari or Firefox (CSS never loads but, more importantly, nothing really works). There are some mentions of that on the Hue forums.
I’m using a REST client to work around this (I chose Insomnia, but I’m sure there are others).
