Hue B Smart - App no longer discovers my bulbs
I’m not sure what’s going with my config. Everything worked fine for a long time, and then even though the app sees the bridge it won’t load my devices any more. It just blinks an pinwheels. I looked in the logs and don’t see errors. Any ideas? I attached a screen cap of what the app shows
You’ll get the fastest answer if you ask in the author thread where you got the original code. The author will be automatically notified when new posts are added to that thread, and other people using the same code will also see it and may be able to help.
In this case:
Make sure your code is upto date in the IDE logs your see 1.71 if your on the latest version
That’s useful info, for some reason my code is updating from github. I need to go figure that out.
