Hey @Diegocampy We took a look at your logs. Thank you for providing them. We are curious to know if you are still seeing this issue? Is it still consistently occurring? If so, could you provide another set of logs while this occurs again.
I can’t tell you @alissa.dornbos ,
If you ask for on or off state sync, it still doesn’t work. For disconnections
yesterday 7 devices were disconnected, today 5, but only some are the same as yesterday, some reconnected independently, some new ones disconnected. Disconnections: switch Vimar, switch (Cina), motion sensor osram, all device ZigBee, with different drive
I see it has been announced that this beta will be the next officially released for everyone. If anyone is interested, as I had already written, the problems remained, indeed with the 49.8 version they even increased compared to the 49.7.
I decided to quit the beta program for this reason, at least that way I’ll get the problems when the others do, and not before
Hi @Diegocampy, thanks for providing the additional logs. We are continuing to investigate your issue with high priority. One additional data point - if you try re-adding the problematic devices, what is the result?
Dear @cbaumler Thanks for your interest. I have not added any problematic devices, as I have never deleted them. Disconnected devices are back online, however, others immediately disconnected and so on for days.
Now all is online from 24h.
The problem left is sync on or off if on or off by physical button.
Glad to hear your connection issues have resolved. Can you tell me the labels used for the devices that are not correctly reporting on and off when you change them manually?
unfortunately 3 Vimar devices (switches) are disconnected again.
All device nomnated Soffitto ______ and, Specchio Bagno, Piano Cucina, Luce fuori Garage, all my device Vimar Switch. No problem with all my switch not vimar. The same problem for other user in italy with the device Vimar.
I don’t see anything out of the ordinary in your logs. Every time a device sends an on/off message I see a corresponding on/off event. However, a lot of the devices you mentioned seem to be using a custom driver, so I have no idea what the driver code is doing.
perhaps because 90% of my lights are switched on by app or by some rule, I rarely switch on and off from physical buttons on the wall. If you give me a space in time, I’ll try to do more switching on and off from the physical button on the wall. I am in time zone +1 (now +2 for daylight savings time)
Yes, that’s true, but I’ve noticed the same problems for both standard and community drives. Now I have 4 devices disconnected, all Vimar, and I don’t think the drive is responsible for the disconnections, but in any case 3 have custom drives, 1 has the standard Zigbee switch (Soffitto Studio)
initially I immediately worried about reassociating them and sometimes they immediately associated themselves, sometimes I had to work hard, until I decided to leave them abandoned, and every now and then they come back online by themselves, and others are disconnected. In addition, alignment problems continue, which does not always update the on or off status.
Even with firmware 49.000009 in my house the problems remained the same unfortunately. now I have 4 devices disconnected, all Vimar.
